NEW - UG802 Finless 1.8 Custom ROM
    Are there any screenshots of the new "grid like launcher" mentioned?
      Re: NEW - UG802 Finless 1.8 Custom ROM - BETA
      Por favor chicos, vamos a intentar usar el inglés, y si tenemos q hablar en castellano mejor por mp o añadimos la traducción abajo, así toda la gente podrá entendernos, si cada persona habla en su propio idioma, esto se vuelve un descontrol. Mi ingles tampoco es una maravilla pero el traductor de Google hace milagros. Muchas gracias.
      Pls, lets try to use english, if we need to speak in other language lets use private mensages, or append English translation. If everybody speaks in their native language this will be caotic. My English is bad too, but with Google translator help we canget miracles. Thanks a lot.
      My devices:
      Gearbest.com)
        Originally posted by fratello View Post
        I think Mr.Finless it's NOT tatubias ...
        So ... what is this : http://www.pandawillforum.com/showth...ustom-ROM-BETA ??????
        I'm not finless I did post there and link it to this thread.
        I have not done muche tweakin on rk3066 chipset. He is the person that has the experience not me.
        Btw. I have my ug802 broken. I need to re solder the micro usb or the cable.
        Btw. Por favor hablen en ingles sino despues es una locura para todo el mundo. Gracias..
        Sent from my MOMO11 四核 using Tapatalk 2
          Sorry, I speak english only whit the other user for he is spanish people.
          Mi other message are in english.
          Enviado desde mi GT-I9000 usando Tapatalk 2
            @tatubias : Please corect your post on Pandawillforum ! You are not the author of Finless ROM ! ("Here is my new UG802 Finless 1.8 BETA ROM.")
              OK,
              I was very tired last night to use the goglee, little sleep research for mk802III
                its a copy and paste only. you are making a hole thing of this. if you took some time to read the post you will figureit out.
                keep helping in the forum, do / take possitive attitude and actions. this is not going any were.
                i will update the post so you are happy and you can sleep this night.
                  OK, thank you ! My problem is that I do not like thieves ...Next time use " ", as I do !!!
                    Pls keep calm, and try to put credits everytime. I just read the post, and now seems correct.
                    My devices:
                    Gearbest.com)
                      Bob,
                      Love your ROMS, but man, please get some help with those cheesy boot screens
                      Anyway, Running this ROM with 2dark's 1080p 1272 OC kernel and its smooth as silk - no issues - antutu @ 8200. The hiding menu bar now allows for xbmc to go fullscreen !
                      Thanks!
                        Originally posted by rapalax View Post
                        Bob,
                        Thanks!
                        Thanks for your input, I put the same kernel, but 1080p 1600mhz, but that's from 1200 .... anyone know why
                        I put it to 1600mhz, with SetCPU, but that's from 1200 ....
                        thanks rom!!!
                          hi bob,
                          i got this error during freshing - Error : download file failed
                          any solution?
                          problem solved.
                          as I still in fresh mode I unplug the ug802 from tv.
                          Then plug it to pc with a shorter usb cable, then I repeat again,
                          it work. thank for the nice rom
                            not working for my ug007
                            hi Bob,
                            I have been running 1.5 for a couple of months on my ug007. recently I beta tested 1.7 on my mk808 and it worked so well I was looking for an upgrade for my ug007.
                            having successfully installed 1.5 for the mini ix I thought I would try your 1.8 on my ug007.
                            I do not have WiFi on my ug007 with your 1.8 ROM.
                            I've gone back to 1.5 for now. please consider a1.8 ROM compatible with the ug007.
                            thanks
                            joe
                              Finless why you put the ID from samsung galaxy SII in the build.prof?
                              if you put the ID of a tablet such as the Nexus 7 not increase application compatibility? or the S2 is better?
                                Originally posted by showkit View Post
                                I have been running 1.5 for a couple of months on my ug007. ....please consider a1.8 ROM compatible with the ug007.
                                thanks
                                joe
                                I will try only to help Bob so as to find correct answer for your question. If you dear colleague were a litle bit more atentive, you would notise that 1.8 ROM is created for UG802 and another related devices line.
                                Your UG007 contains another wifi chip and BT chip in addition which can not be supported by this new 1.8 ROM.
                                CS918II/16GB(HTC-031-V1.0 board)
                                CS918 (TN-BX09_V2.1 2013/05/31) FW: k-r42-old_revision-wasser-1.2.3- fried by 12V PS
                                K-R42 board version B351_V2.0 1348, wifi Realtek8188ETV , RK3188T;FW: wasser-firmware-kr42-new-1.0.3
