NEW - UG802 Finless 1.8 Custom ROM
    Is there an easy way to allow the kernel to do overclocking with an external app like setCPU ?
    I know that in the previous ROM, OC kernels were available, but I wouldn't want those clock speeds available until I run some stability tests, etc.. then by setting a 'set on boot' flag the app would bump up the clockspeeds after boot.
    Could I just flash that 1.7 extreme OC kernel over 1.8finless and then start testing what speeds are ok, or do I risk having the device bricking up on boot as it tries to run things too quickly at startup.
      Yes, you should be able to use any over the OC kernels out there with 1.8 ROM. I have not tested them all but I have seen good reports.
        RTL8188
        rtl8188 still not working on this rom
          This rom version 1.8 work to the mk806 and mk809ii ?
          Thanks for this great work.
            Hi, Bob!
            I have got an UG802 V2 with Realtek 8188EUS wifi chip. See the pictures bellow. I saw on the other forum topic (another clon UG802_9) you made an 1.7 rom which work with 8188 wifi chip. My mini pc is different inside than UG802_9. The "original" Finless 1.7 or 1.8 ROM is working fine for me except the wifi. Can you place the 8188 driver to 1.7 or 1.8 ROM or it's a hard work? (1.8 would better :-)
            Thanks for great Fineless Roms!
ID:	429962Click image for larger version
ID:	429963Click image for larger version
              Try my beta test CLONE ROM here:
              The link is near the end of the thread.
                Hi, Bob!
                And that's good for me? My minipc is different then UG802 9?
                I will try to flash.
                  R: NEW - UG802 Finless 1.8 Custom ROM
                  Hi Bob, this Rom work on mk802III like a 1.7 version?
                  I can try only ug802 Rom in mk802III ?
                  I don't find roms for mk802III...
                  Can you help me?
                  Inviato dal mio Galaxy Nexus con Tapatalk 2
                    MK802 IIIS
                    Hi I bought mk802IIIS. Rom work ok, but wifi not. I dissasembled unit to see that contain RTL8188 but i cant see chip with realtek. See below.
                    Im including dmesg.txt too. But there is talking about rtl chipset. Im little bit confused.
ID:	429966Click image for larger version
                      Im including [ATTACH]1938[/ATTACH] too. But there is talking about rtl chipset. Im little bit confused.
                      [ATTACH=CONFIG]1937[/ATTACH][ATTACH=CONFIG]1936[/ATTACH]
                      Hi!
                      The wifi chip is on the top left section on the pcb (2nd picture) You can see the gray colour wire left side from the wifi chip. Under this chip is a bluetooth chip. Both Mediatek. The MK802IIIs has MEdiaTek wifi chip and bluetooth, the MK802iii has Realtek 8188 and assembeled without a bluetooth.
                        Originally posted by MGa73 View Post
                        Hi!
                        Its
                        mediatek mt5931SA
                        mediatek mt6622N
                          [[email protected];59778]Its
                          mediatek mt5931SA
                          mediatek mt6622N[/QUO
                          MT6622N - Bluetooth 3.0. MT5931SA - WIFI B/G/N
                            Hi, Bob!
                            I flashed it. But I haven't got wifi connection. I try to reboot and unplugedd it form connector and pluged again the result was the same. Under Clone UG802 Stock ROM the wifi was fine. I don't understand. I have got Realtek 8188 too like another clone forum. Why doesn't work form me?
                              Which ROM ?
                              Im not sure which ROM to load in my device
                              MK802 IIIS - Bluetooth
                              Chipsets
                              mediatek mt5931SA
                              mediatek mt6622N
                                Thanks Bob,
                                But are the clock speeds limited to stock values on boot ? If not, it might brick my device before I get a chance to down-clock it ? Most cpu apps will let you try out higher clockspeeds before setting the new value on boot.
                                The 1272 Kernel is working great for me so far on 1.8, and want to take it to ~1400.. But I hesitate in flashing the faster kernels for fear it won't boot.
