UPDATE:
Using terminal emulator I issued su followed with reboot bootlaoder I managed to flash it.
The android appeared and it falshed and reboot.
Now, it stucks at boot screen. Could be because I put 2dark kernel instead of the stock one?
Also I used 2 GB parameter, as the stick has 8GB.
Managed to short pins 6 & 7 and re-flashed with stock kernel. It is working now. pheewww :|
Hi there,
I have MK802III and flashed to Finless 1.7 and it works, thanks Bob & 2dark
Now I want to use this 1.8 version. I am able to get "Found RKAndroid Mass Storage Usb",
but when I clicked "Reboot to Flash Mode" it prompted me "Flash Mode failed".
The HOST port is connected to the laptop.
The DC port is also connected to the laptop.
The same laptop was used when upgrading from the original fw to Finless 1.7
Is there anything I missed?
TIA
