NEW - UG802 Finless 1.8 Custom ROM
    Excellent rom Bob!! Just flashed this today no problems so far.
    I used the 1080p kernel from your 1.7...overclocked to 1.6ghz and stable.. so far. I modded with heat-sink and bigger case w/ omni-directional wifi antenna (full-bars)!!
    -XBMC works fine as does Netflix
    -Installed Button Savior from the market (a must have if you hide the task bar)
    -sleep mode works (if you have RC11 air mouse, just hit the power button.
    -i also installed Null Keyboard it makes the on screen keyboard go away.
    Nice boot screen!!
    Thanks again!!
      Originally posted by sirdicholas View Post
      First off, love the rom. Thanks for all the hard work. Secondly, how do I restore the status bar after is hidden with a keyboard?
      You should download Button Savior from the playstore.. it puts a tiny transparent trigger in the corner of the screen..when you click it, it brings a tiny taskbar up. I know your looking for a keyboard solution but I hope this helps.
        Originally posted by Wolfsteen View Post
        Hi all,
        I have flashed new Finless ROM 1.8 with repaired libstagefright.so file. Movies playback now goes fine via MX Player and BS Player, but via XBMC some movies are still not go smoothly. I don“t understand why. Where is the problem? Thanks for reply.
        The problem is with xbmc itself, it's still somewhat beta and there still working out H/W accelleration.
          I just flashed my mk809 (ug802 clone) with Finless 1.8 wifi works but max download speed is 2Mb (my internet speed is 20Mb) I recieved my device yesterday and flashed with this rom for wifi and other benefits but there is no wifi improvements for me. I like this rom and i dont want to go back to stock rom. Included video player play 1080p video smooth (cartoon for my daughter and was choppy in stock rom). Nice job BOB. I notice after reboot my wifi is allways off i have to power off and on again to wifi start working.
          PS sorry for my english
            Hi,Bob
            very good rom I try it on my Mk802 3, and 1080from your 1.7. the only problem is when I use auto hide bar, mx player bar will be very hard to use since it dissappear very fast.
              R: NEW - UG802 Finless 1.8 Custom ROM
              @GZD
              Have you flashed with 1080p kernel and boot?
              Inviato dal mio Galaxy Nexus con Tapatalk 2
                Originally posted by s8vuoto View Post
                @GZD
                  @GZD
                  yes, I use 1080p kernel and boot. everything is smooth. Just the hide bar function work not very good In xbmc and will make some problem. But when I disable from setting. still no arrow button from the function bar.
                    Tnks
                    I'll try....
                    After you feedback I've flashed but with 720p ....
                    Unfortunately for mk802III there are not (recently) Rom specifically for this device
                      firmware for UG007
                      Hello Bob!
                      thank you for your fantastic work!
                      Several posts above you said that if someone gives you link to stock firmware of UG007 you can make a custom rom especially for this device.
                      So the last official ROM is there http://www.kuyoule.cn/upload/update_99753.zip
                      I try on my UG007 ROM for Imito 1.5 1080 and Measy 1.7 1080. They work fine but maybe if you look the stock ROM for our device you can do a miracle with it?
                      Thank you in advance. I can test ROM and recommend the ROM on other site where many users of UG007 discussing the device.
                        Hello Bob, I just got my UG802 with device info as follow: Kernel Version 3.0.8+
                        Build Number
                        RK30_ANDROID4.1.1-SDK-v1.00.1015
                        rk30sdk-eng.4.1.1 JRO03H eng.ant.20121217.100738 test-keys
                        Will your latest 1.8 for UG802 work on this ROM with stable wireless and ethernet USB dongle?
                          Build Number
                          If I can help you too....with my experince. It's depending on which modell have you got? If you have got UG802 with Realtek8188 the wifi will not work under 1.8 fw.
                            I really don't have a way to know which wifi without taking it apart, so I took a chance, and it worked.
                              You're lucky
                                Webcam working
                                I can confirm that webcam is working (including MIC) with Logitech C270.
                                It's great for Skype video calls
                                Finless thanks for this ROM, keep up the good work
