Sent from my Nexus 10 using Tapatalk 4 Beta
NEW - UG802 Finless 1.8 Custom ROM
Bob, Thanks for a great ROM, after my MK808 died I recently bought a re-branded UG802 its a TV-HDMI-KB-01 from Point of view (the PCB says HTC-T002-V1) I installed this ROM and everything seems perfect, except for one thing and it might not even be related to the ROM, just want to check if anyone else has the problem I have problems playing video streams The YouTube app sometimes plays the video and sometimes it doesn't, if I change the quality then the video hangs on on loading circle, the app is not frozen, it just doesn't load the video. I thougt this was a problem only with the YouTube app, but the same thing happens with XBMC.
internet does not seem to be the problem since I can browse and do other online activities without a problem.
This does not happen on the stock firmware (which I am using now).
anyone got any ideas ? or does anyone have the same problem?
Thanks!
Originally posted by niabi View PostBob, Thanks for a great ROM, after my MK808 died I recently bought a re-branded UG802 its a TV-HDMI-KB-01 from Point of view (the PCB says HTC-T002-V1) I installed this ROM and everything seems perfect, except for one thing and it might not even be related to the ROM, just want to check if anyone else has the problem I have problems playing video streams The YouTube app sometimes plays the video and sometimes it doesn't, if I change the quality then the video hangs on on loading circle, the app is not frozen, it just doesn't load the video. I thougt this was a problem only with the YouTube app, but the same thing happens with XBMC.
Thanks!
did other tests, and it seems it might be some updates on the play store, if I install the ROM and don't install updates, then everything seems fine, the moment I install the updates, then it starts to fail... will look into what app is the one causing this
plays the UG802 really FullHd
Hello Together.
I have the UG802 for more than 6 months with Finless 1.6. Now I wanted to flash another 1.7 or 1.8. But I always read 720p Kernel, 1080p kernel. What is the difference now? I always thought the UG802 plays FullHD from. I can adjust settings at 1080p with 50-60 FPS.
What is right?
1. I have a 720p kernel he plays 1080p -> 720p <- 1080p. (Source - Systemresolution - Upscaling)
2. I have a 1080p kernel he plays 1080p - = 1080p = - 1080p.
Or it does not matter which kernel I have?
Yesterday I have tried many combinations. Somehow, 1.7 and 1.8 were not as stable as 1.6
Originally posted by AndryBlack View PostBob, please share you .config from kernel build. I need build some additional modules
I have found the answer in the forum Allminipc.com.
that's crappy. It is advertised with full HD, but it's not true.
720p vs 1080p
There are 720p kernels and 1080p kernels available.
These devices by default have a 720p kernel, meaning the "internal system" will run at 720p resolution no matter what. Even if you set the output to 1080p under settings it will just take that 720p resolution and upscale it to 1080p.
So when you watch a 1080p movie on a 720p kernel (and the output set to 1080p under settings), that video image will first be downscaled to 720p (loosing detail in the process) and then upscaled again to 1080p (just increasing pixels, not adding detail) before it's send to the TV/Monitor. So even if you are able to play a 1080p movie on a 720p kernel, all detail over 1280x720 resolution will be lost. That doesn't mean it still cant look very good and you'll have the benefit of a fast running android and other apps. Also i think you will be able to play 1920x800 resolution videos (a very common movie resolution) without having to overclock the device (even though you wont get the full detail).
With a 1080p kernel you will have real 1920x1080 output to your TV/Monitor. Meaning when you watch a 1080p movie you will also see that 1080p detail. However with a stock/non-overclocked kernel you wont be able to watch even the lowest common 1080p movie resolution which is 1920x800 without a lot of dropped frames. So you will have to overclock...
So with 720p kernel you can play (most) 1080p movies, but you wont see the detail so there is no real reason to watch a 1080p movie. And with a 1080p kernel you will be able to see the extra detail of a 1080p movie but you wont be able to play them!!!I think that's what they call a "catch 22"
Unless... you overclock...
Originally posted by zasten View PostActually after repeating the flash (after re-downloading the rom) it seems that I am stuck on the boot screen again. No progress after more than 10 minutes.
Anyone else with the same issue?
Looks like I will be going back to 1.7 and try to flash libstagefright.so from CWM.
There are currently 2890 users online. 0 members and 2890 guests.
