XBMC / Kodi on Linux/RK3288
Originally posted by peba View PostIf you experience performance problems in linux (like audio stuttering in Youtube or Kodi) you can try to set the cpu governor to performance:
open a terminal window:
$sudo su
root@ugoos:~# echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
This will set the cpu clock to maximum (but it does not enable overclocking).
So out of the box your RK3288-SOC cpu will then run at 1.8 GHz and will not switch down to lower frequencies.
Originally posted by Shadi86 View PostAny easy tutorial how to install only Linux?
For flashing dualboot or clear(just Linux) linux firmware
1. Run the Android Tool. If you did everything correctly and the driver is installed on your
computer, you will see Found One Loader Device
2. Default program configured to flashing "clear"(just Android) android on your device. If you want install
Dualboot or Clear(just Linux) linux click right mouse button by program window, and then select
Load config.
3. Then choose one of configurations files:
config.cfg - if want flash only Android
config_dualboot.cfg - if want flash dualboot
config_linux.cfg - if want flash only linux
4. Now click the Upgrade button to the firmware of the device. At the end you will see a sign
indicating a successful operation.
Originally posted by RISCy Dude
You will find a pdf in the update file(config files too), this is from page 9 of that document. I amended the following by adding the(just Android) or (just Linux) for the sake of clarity.
Load config.
So in androidTool i need only change to config_linux.cfg, but in the pdf manaul i couldn't see in Wich box i will put the config_linux.cfg is it box nr 1 or 8? And do I need change anything more what about all the image in the folder, I can see" linuxroot.img"and etc, do I need add anything more in the androidTool? In the firefly it's easy it's only one image to add..sorry I'm noob and I appreciate your help my friend
Then it automatically changes all the boxes and files to the correct ones.
Added "HOW TO INSTALL IT YOURSELF (on a debian based linux)" in 1st postSupport my work to make you a better multimedia experience...
And Donate...
Originally posted by MAC_L1 View PostAdded "HOW TO INSTALL IT YOURSELF (on a debian based linux)" in 1st post
Originally posted by gffmacTried the linux only and dual boot configs. Enabled auto ethernet setting then loaded up kodi and tried a test video: https://dl.dropboxusercontent.com/u/...15.57.29-1.mp4
Should I expect it to be at least as smooth as android? Also notice the audio stuttering. 720p seems to be a bit better.
Thanks for your hard work MAC_L1
Need to update the Android firmware to v2.0.8 through settings for passthrough to work on all receivers.
Since the Linux Kodi also use Android drivers it might work, otherwise a new Linux kernel needs to be compiled with passthrough support.
Someone please test passthrough then I will create a new ROM if it works.
Also test 1080p 23.976 videos in Kodi Linux(might not work smoothly but need feedback).
And Donate...
There are currently 2871 users online. 1 members and 2870 guests.
