Thank you for your efforts on these T-Chip devices. You are a huge factor in HPH's, Ugoos' and Firefly's success. You certainly improve the user's happiness with these devices.
XBMC / Kodi on Linux/RK3288
Originally posted by Shadi86 View PostThe audio issue seems gone, excellent!
I have install spmc, in the spmc setting/audio I can't choose spdif to passtrough any workaround?
And how to auto boot kodi/spmc?
Good luck.
UPDATE: I meant to add, that after installing PA, a reboot is necessary.
Originally posted by RISCy DudeI installed Pulseaudio, afterwards, SPDIF will be available as an option in Kodi. I would think much the same for SPMC, but it is not known to me. Give it a try, you can always uninstall Pulseaudio if it doesn't work in this case.
Good luck.
Originally posted by MAC_L1 View Post
Hi Martijn, Shadi86
I made a little sound fix that worked at least for my firefly distributions. It is installed during my script, however you need to set your audio settings accordingly.
So in kodi go to: system->settings->system->audio output->audio ouput devices and then select the mixer (last entry i believe) as your audio device.
Then probably best to restart kodi.
Hope this works!
Originally posted by Martijn View Post
My Audio output device is locked as "Default (RK_ES8323 Analog)". My guess is I need to install a manager to allow switching audio devices. It's a fresh install from the latest official firefly dual boot image, so I'll look at that.Support my work to make you a better multimedia experience...
And Donate...
Originally posted by Shadi86 View Posti can't download the link you have in your site, machybris-rk3188_4.4.2-0.1.1_armhf.deb 0.00...any workaround would be great
Or try in a terminal/shell: curl -O machybris-rk3188_4.4.2-0.1.1_armhf.deb http://www.mac-l1.com/v0.1.1/machybr....1.1_armhf.deb
BEWARE: we are now talking about RK3188 instead of RK3288...
However, my install-script "./install_machybris.sh" should do all the downloading itself...Last edited by MAC_L1; 16 November 2015, 10:56.Support my work to make you a better multimedia experience...
And Donate...
Unfortunately the helix script has an issue. Guessing a link that needs to be updated
--2015-11-16 18:21:38-- http://mac-l1.com/v0.1.1/mackodi_hel....1.1_armhf.deb
Resolving mac-l1.com (mac-l1.com)... 2a01:238:20a:202:1144::, 81.169.145.144
Connecting to mac-l1.com (mac-l1.com)|2a01:238:20a:202:1144::|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2015-11-16 18:21:38 ERROR 404: Not Found.
Should be
http://www.mac-l1.com/mackodi_helix-....1.0_armhf.deb I believe. Or you can move the file obviously. Or the 0.1.1 version is just missing.
Edit: nm, it straight up doesn't seem to work with the 1.1.0 deb, so I guess it just won't work with the new script. Idk, more tomorrow. Maybe just install the old image, then just run the sound script. See if that's enough.
Originally posted by Martijn View PostUnfortunately the helix script has an issue. Guessing a link that needs to be updated
Should be
however still strange that hevc isn't working for you; did you try mackodi v0.1.1 instead of macspmc?Support my work to make you a better multimedia experience...
And Donate...
Originally posted by MAC_L1 View Postactually haven't uploaded helix yet, as it is the same code as my first release 0.1.0 from a few months back.
I tried the install_mackodi.sh on Firefly's latest dualboot image. Firefly-RK3288_DualBoot_201501271613.img. And that ended up working but without hevc. Don't waste any time on looking into that, I'll flash it again and see if it's a one time thing or just how it is. I also want to try macspmc anyway, so I'll hit that up too.
Hi Mac! I've tried to install Kodi on Fireprime board (rk3128) and can run it successfully! But when I tried to install Kodi on another rk3288 board (not Firefly series) with Debian, although I could install it, it crashed when i tried to run it. All I can read on the terminal shows like following:
#kodi
/usr/bin/find: `/sys/class/display/*/enable': No such file or directory
*** Error in `/usr/local/lib/kodi/kodi.bin': free(): invalid pointer: 0x035ce6bc ***
Do you have any ideas how to fix this problem?
There are currently 2558 users online. 0 members and 2558 guests.
