Beta Lollipop Firmware - MXIII-G(S812+1/2G+GigaEthernet)
    This can work with the m8s ? Someone try this with the m8s
    Sent from my SM-G928F using Tapatalk
      I want to buy this device?
      does this box have googlecast reciever support like nexus player/nvidia shield TV?
      Can anyone confirm me?
      Thank you.
        I try m8s but the WiFi and the remote not work please help me how I can fixed
          I'm looking at getting the S812 2g version. Lollipop is not getting good comments on here for tv streaming which worry me. I'll be using the box for streaming primarily. Any guidance on if I should go ahead with lollipop? I'm tossing up between this and the U BOX i one (i828) TV Box Amlogic S802 Android 4.4.2
            @Steve-o: This is a very old thread. I think that 106L1 is the latest version of Lollipop which runs on both the MXIII Plus and MXIII-G. If you prefer you can change to the 316k4 Kitkat firmware. The S812 offers many more features than the older S802 model, Gigabit LAN, 4K H.265 playback, Lollipop firmware, faster graphics etc. Just make sure that you purchase the MXIII-G from Gearbest or the MXIII Plus from Geekbuying as most of the machines that are being sold on Aliexpress/Amazon/**** are not genuine. It is probably worthwhile to choose the 2GB Ram option as this should improve gaming and Kodi performance etc. The number of different firmwares that are available for these two devices has made them very popular choices.
            106L1 Lollipop firmware
            http://freaktab.com/forum/tv-player-...e-106l1_151029
            316k4 KitKat firmware
            Tronsmart is a leading brand innovating cutting-edge audio products such as speakers & headphones with premium sound quality.
            This is the MXIII-G OpenELEC thread
            http://freaktab.com/forum/tv-player-...g-amlogic-s812
            Review of MXIII-G
            http://forum.xda-developers.com/andr...eview-t3160863
              Cheers for the advice and info mate. Yeah I bought a MK809IV Plus from Gearbest, my first tv box. Not even a week later and I'm looking to buy a bigger better one. I'm more informed now thanks to freaktab.
                So my MXIII-G 2GB version arrived and I'm having problems with buffering with most Kodi 15.2 sources (Genesis, SALTS, 1Channel, etc) however I can play 1080p HD movies through Phoenix (gvideo) no problem, same with HD YouTube videos. I tested with the exact sources through Kodi 15.2 on my Linux machine and they work no prob.
                If I go to system info for my MXIII-G it shows build 106L1, Lollipop 5.1.1.
                Does the OpenELEC firmware solve issues like these? It's a pity because everything else on the box runs perfectly.
                  Review of MXIII-G
                  Lurker can you post the download link 106L1 Lollipop firmware? The link is broken
                    Hi,,You Can find the 106L Here
                      can I use 316k4 KitKat firmware with MIII-G 2 GB/16 GB?
                        Originally posted by TOSanthony View Post
                        Hi, how to add support of ethernet 100Mb? My tv box have the same cpu but ethernet is 100Mb not 1gb speed.
                        Yes, please someone add support for 100mbit ethernet.
