Beta Lollipop Firmware - MXIII-G(S812+1/2G+GigaEthernet)
    Download Link:
    MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
    Tool:
    Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
    Nice I need one of these boxes
      Originally posted by oman View Post
      Download Link:
      Tool:
      What about Lollipop for Beelink with SoC S802 like Beelink M8 ?
      Do you plan to release a new firmware ?
        Thanks for this oman,Downloading & will test this latter
          Thanks Oman,
          I have a question:
          I bought one of these boxes from Gearbest, it came with 316k4 firmware. is it the latest Kitkat version? cause I found 116k4 as latest one.
          should I replace mine with 116k4 or your beta Lollipop? I have problem in video playback either with Kodi or android apps like Vevo and youtube, the video is not smooth and jumps. does this fix that? or any other solution?
            What about s802 devices?
              Exactly, what about S802 devices?
              If the S802 lollipop driver binaries were shared - we'd be able to compile it ourselves....
                I'm gonna see if it breaks my device (mxiii s802 2gb)
                edit:massive file, and img file means burning rom.
                  I can confirm the following:
                  Tronsmart MXIII (2gb, 8gb Rom, s802)
                  1) The rom installs fine using USB burning tool provided
                  2) Ethernet works !!!!!!
                  3) WiFi does not work
                  Beelink S82 Plus (2gb, 16gb Rom, S812)
                  1)Rom installs fine (takes 4.12 minutes)
                  2) Ethernet works
                  3) WiFi works too!!!!
                  Note: First boot takes a while. melee f10 pro causes sound issues like in early KitKat ROMs. So sound about is needed.
                  Settings are hard to find. I cannot get on screen buttons to appear, home button isn't working,
                  The rom is not rooted
                    MXiii G Android 5 Lollipop Rom
                    The rom flashing process went with out any problems very easy to do & like Dandroid534 said it takes about 4/5 mins on first boot
                    Home screen
                    Cpu z
                    Antutu Video
                    The Rom is running very nice indeed iv not came across anything thats not working yet.
                    Its not rooted but easy to root with iroot
                    Nova Launcher working like a charm snappy as hell
                    More to come
                      I rooted by using twrp and SD card, and flashing latest SuperSU
                      Are onscreen buttons working?
                      And what remote are you using?
                        On screen buttons?
                        Do you mean the status bar at the bottom? as that's missing.
                        The remote that came with the MXiii G works fine but I use an airmouse or a normal mouse
                          Yeah drag up. Melee f10 pro home button does take me home
                          Also, I can't see notifications, even when I shrink screen
                            Again what's the deal with S802 Devices.... Will we, or won't we ever get to see the backside of Kitkat? By the way.... Is anyone else here aware of the MASSIVE Bug in Stagefright?! AFAIk even KK4.4.2 should be affected. This alone should be enough for any serious Company to issue a update... But, then this is Bee Link we'er taling about... A Company that can't even be arsed into fixing the Large TCP Buffers on its Devices... Cause MXIII's should only be used on GSM Networks! Along with the mysterious False Statement (build.prop): media.amplayer.widevineenable -- The absence of which almost guarantees Google Play Movies WILL NOT WORK! Reportedly along with the BBC iPlayer... Though I can NOT vouch for the latter.
                            But, a Company that can't fix stupid simple crap like this... Isn't probably likely One that's anymore interested in protecting their Customers Privacy, and Security either.
                            *EDIT / UPDATE*
                            Having taken a cue from some of the other Posters here I thought I'd try this on my M82 (1G/8G MXIII - S802 - AP6181 Device).... = SOFTBRICK
                            Thankfully I'm still somewhat able to enter the 3e Recovery, but there I'm greeted by a slew of failed to mount (no such file or directory) Errors. So this may well be a 2G/xG ROM ONLY, just like the good old days before AiO came along, and broke everything on the 1G Version. amcodec I'm looking at you!
                            So its back to 109k4 again thanks to my Nandroid backup...
                            Hopefully it won't be too long now, before S802 Users get their suckers too....
                              *EDIT / UPDATE*
                              I think you should just buy a tronsmart mxiii g from. Geekbuying, your life will be much less stressful! They are like £45.
                              Also before you install a rom you should do a twrp backup
