Beta Lollipop Firmware - MXIII-G(S812+1/2G+GigaEthernet)
Iv just tested this Fw on my Venztech v8 (Wifi chip ap6335)
Rom installed fine
1.wifi (works)
2.Ethernet (not working)
3.Bluetooth (not working)
4.V8 remote (no longer works) but the mxiii G remote does work
5.The didgital clock on the v8 box (no longer works) Expected this not to work
Switched back to the v8 stock rom with out any problemsPlease consider making a Donation to freakTab
Pretty sure HEVC is broken for kodi in this build. Playing a hevc/x264 file results in kodi freezing the whole box.
Edit: Scratch that. Working. Did a fresh install of both rom and kodi and now its working.
Edit #2: I am seeing problem playing files with HE-AAC when sound output is set to 5.1 in KODI. Causes the box to freeze. This is the problem I was experiencing above. When set to 2.0 the box does not freeze.Last edited by Takenover83; 08-04-2015, 17:50.
Originally posted by jamal2367 View Post
Same here... Wait for wifi driver for s802 in the kernel
No news from Oman, hopefully he is busy adding the WiFi drivers and other problems
Guest
Originally posted by Dandroid534 View Post
If u install it you can see what drivers are included, doesn't have anything to do with being s802/s812. This rom works with both chips. Not sure why they wouldn't include the wifi driver from the most common s802 box, mxiii 2gb, unless they just want people to buy the new box...
Yes i have the 2GB Version S802 ...the Firmware works fine but wifi is the issue .... The one question is ..can the wifi drivers not just add in the kernel from the s802?
can someone send me twrp virgin backup?
CheersBugs are Sons of Glitches!
JustMe
There are currently 3040 users online. 7 members and 3033 guests.
