Beta Lollipop Firmware - MXIII-G(S812+1/2G+GigaEthernet)
    do full wipe then reinstall 116
    Bugs are Sons of Glitches!
    JustMe
      You have to install 316k4 OTA.
        Only if you want WiFi
        I believe the only difference is the kernel for 115k4 and 316k4. 202k4 also has a different kernel I think.
          Is there an stable version already out?
            Originally posted by 0bey View Post
            I Just receive this box (mxiii-g from gearbest) and I have put this rom after à quickstart on kk.
            I don't try wifi but all work fine exept Google play services. So all or almost create FC of Google play service...
            I have try to update gplay with apk, remove update of services, reboot, delete cache, facture reset, re installation of rom...
            Any good idea ?
            I had the same problem as you. Check your system date and time (some date from 1970). When I correct the date and time, I successfully connect to Google Play service.
            Does anyone know how to setup or tweak configuration to support Minix Neo A2 air mouse? When I connect it to MXIII-G there is no sound on TV.
              Use sounabout and disable USB audio? Or go back to kk and option is in settibgs
                I have beelink s82 plus and wanted to install this rom however I would like to know how I back up my current rom which is stock 202k4 incase I need to go back.
                Pabloe
                  Thanks, that help me to resolve issue.
                    Any chance of getting this fully working on the Tronsmart S89/Beelink M8? I have 5 of them round the house (two on ethernet, 3 on WiFi), so would rather get a fully working firmware on them than have to replace them all....
                    As things stand, I have still to find a ROM I am happy with - mainly used with Kodi/TVMC and all require regular reboots, which is annoying - would be nice to get the Google TV interface as I am not a fan of the MBOX launcher.
                      This rom works on beelink s82 plus but not ethernet
                        Beelink s82, 8 GB.
                        Rom doesn't work. Only the logo boots.
                          You realise there are lots of launchers on playstore? And launcher is different thing to rom? I use Nova launcher.
                            beelink s82 plus works but no ethernet
                              Someone have Google play store Leanback mod works on cpu arm and with this rom?
