Beta Lollipop Firmware - MXIII-G(S812+1/2G+GigaEthernet)
Originally posted by cs918king View PostI have downloaded this beta rom and installed it on my MXIII 2GB/8GB Box and Wifi/Ethernet/Bluetooth all Works 100% no buffer issues and even apps that never worked on no firmware work on this it has made my box worth using all over again
Help a noob out!
I have my MXIII-G 5.1 android S812 2/8 gig with gigabit ethernet stuck in a boot loop for doing something stupid in Android 5.1. It boots and then 30/45 seconds later boots again.
Doing the onboard factory restore didnt fix it. I need to flash the firmware.I got the package from Mediafire link and have hit two brick walls.
Using the onboard restore with USB the recovery app doesnt see the IMG file on USB. Its see's other files but not the IMG.
Using the bootloader route my Windows 7 PC doesnt see the MXIII connected to the OTG port while in recovery mode. If I let the MXIII boot naturally The PC see's it but then the box reboots and etc etc etc.....
Is there a specific ZIP package that it needs that I havent found that the onboard USB recovery will see? Is it my Windows 7??
Thanks!
Thanks!
Originally posted by mowgli View PostI don't own this box but I read in some of other threads before that this could be caused by an sdcard/usb with a recovery image left in the slot. Once again, it's just a thought.
Not sure I'm following. The recovery app reads the USB it just doesn't see the only IMG file that's on it.
Originally posted by mowgli View PostWhat I meant was that it is possible that if you have an SDCard/USB with firmware or recovery inserted during restart it might cause the issue. Just try to boot with empty slots.
This is my first Android or OS on a chip device BTW. Live and learn.
If I can get the firmware reinstalled it should rectify the issue.
Hi. I've just received a MXIII-G 2Gb from gearbest. It came with android 5.1 firmware. Everything works great, but I have an important bug. When I try to connect a keyboard to an usb port (I tried a wireless keyboard with rf receptor and a bluetooth keyboard) I have each some seconds this message "Unfortunately, Google play is stopped". If a unplug the keyboad, the error messages dissapears and everything works right. I tried this same keyboards on an android 4.4 tablet, a MXQ setbox with android 4.4 and an smartphone with android 5.0 and allways they work right.
A friend bougth the same MXIII-G and he has the same issue when I plug a keyboard. I think it may be a firmware bug. Can anybody test it? Is there a workaround or fix for that. It's usefull to use a keyboard to set up this box and surfing on internet.
Thanks.
Originally posted by langostino View PostHi. I've just received a MXIII-G 2Gb from gearbest. It came with android 5.1 firmware. Everything works great, but I have an important bug. When I try to connect a keyboard to an usb port (I tried a wireless keyboard with rf receptor and a bluetooth keyboard) I have each some seconds this message "Unfortunately, Google play is stopped". If a unplug the keyboad, the error messages dissapears and everything works right. I tried this same keyboards on an android 4.4 tablet, a MXQ setbox with android 4.4 and an smartphone with android 5.0 and allways they work right.
Thanks.
iv seen this on a few devices now running lollipop so I would guess its a lollipop bugPlease consider making a Donation to freakTab
Originally posted by langostino View PostI'll try it. But if I uninstall updates on google play, can I install apps from it?Please consider making a Donation to freakTab
There are currently 3251 users online. 2 members and 3249 guests.
