Beta Lollipop Firmware - MXIII-G(S812+1/2G+GigaEthernet)
    Originally posted by oman View Post
    Download Link:
    MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
    Tool:
    Thanks for the rom Oman. Will you be adding the following?
    1) more WiFi drivers e.g s802 mxiii and s89 drivers
    2) on screen navigation bar like on old rom
    3) sound option that doesn't need sound about (USB devices)
    4) make status bar visible?
    5) support for melee f10 pro (lots of people have this airmouse)
    Thanks again
      Originally posted by Dandroid534 View Post
      I think you should just buy a tronsmart mxiii g from. Geekbuying, your life will be much less stressful! They are like £45.
      Also before you install a rom you should do a twrp backup
      No I was thinking... If anything I should be buying a Minix Neo x8-H Plus... The only thing I'd like to know is what's the deal with Android 5.x on those? Seems like even Minix can't be that arsed about it.
      Thanks again
      I won't go as far as to sam I'm 100% sure of it, but, I think you can fix Points 2 &, 3 by modifying your build.prop File
      Code:
      persist.sys.hideStatusBar=false
      #disable usb audio
      persist.sys.disableUsbAudio=false
      By all rights adding these lines into your build.prop should re-enable these things, but YMMV...
        I've had no problems with any of my s802 devices, but all have been 2gb versions. MINIX is too expensive IMO.
        I will try those things shortly
          Good sound!!!!
          At the moment this Beta i flashable on S802 2GB generic???
          Wifi work??
          Thank's
            WiFi does not work on mxiii s802. Ethernet does.
            Code:
            #disable usb audio
            USB audio work, status bar did not.
            Melee f10 pro is incompatible it would seem.
            Remote that came with it works, as does another cheap airmouse, including home buttons etc.
            Another problem I am not having is....
            I can no longer turn on Ethernet on s812
              Thank's!!!!!!!!!!!!!!
                Has anyone had any better luck with the M82 (S802 - 1G/8G - MXIII - AP6181 ~ca. August 2014), Device?! I tried to install this. and only managed to soft-brick my MXIII.
                I'd love to know if this Device even has a future, or not...
                  Did you wait long enough for it to boot first time?
                    This firmware doesn't work with S802 Beelink M8 2G/16G. It stops at the beginning. (wait about 20 min and nothing happened)
                      Well how long was I supposed to wait for... My box was dead. Entering recovery 3e... I was greeted by numerous filesystem errors, and the Box was showing no signs of ever booting ever.
                      Have you tried flipping the values for the Stausbar?! I only lifted those values from some generic build.prop as an example.
                      As to your Airmouse you might find clues to it from older Firmwares that supported it. If I were in this predicament, it would likely be the first place I'd start looking.
                      Otherwise you'd have to learn the Codes, and their relation to the "Vendor_0001_Product_0001.kl File. As if you were eventually trying to alter a Harmony Remote with a PIVOS Profile. Though I gather an Air Mouse may prove more complicated then just that.
                        I got it on the mxiii successfully. But have gone back to 115k4. I will wait until 102L4 to be released. And the problems should be easy to fix, considering as you said there were similar issues with the K firmwares.
                        I suggest you boot twrp recovery from an sdcard and wipe everything, then reflash 115k4, as I too had a couple of funny errors when going back.
                          will this work with i826 too ?
                            I have my reasons.. But, I'm sticking with 109k4. Actually those reasons have to do with me being on a 1G/8G Device, where everything post 111k4 breaks the Hardware acceleration (amcodec), for whatever reason. The only Firmware that has constantly worked for me was 109k4, or 110k4. both of which had a separate 1G release. From 111k4 on its all been a huge snowballing AiO cluster---k, and I doubt anyone there ever payed the 1G much mind.
                              The only way to know is to try and install it, if it is s802 or s812 then it has a good chance of working.
                                Big problem is WIFI.......
                                I will try to install, but without wifi is inusable...
                                I wait news about Wifi fix.....
