MK808-B (original) JB 4.2.2 Official - Finless ROM 2.1
    What is the hint to make possible to wake up mk808b after going to sleep?
    Is it working in 2.1?
      Mine never sleep, I have active "stay awake" in /settings/development options
      My devices:
      Gearbest.com)
        Thanks Bob for doing all the hard work!
        Guys, is it "worth" updating from 1.7 to 2.1.
        Is the performance really so much lower?
        Thanks,
        Tek.
          Thanks,
          Tek.
          Nop, my feels are that it runs very smooth. And the kernel have not a locked clock like in the 4.1.1 to 1200. (that can cause a lot of stability problems, if you feel that 1600 cause freezes and reboots, try to run at 1500 or 1400)
          My devices:
          Gearbest.com)
            Re: NEW - MK808-B (original) JB 4.2.2 Official - Finless ROM 2.1
            So the kernel is unlocked, it goes all the way to 1,6 ghz?
            Sent from my Grand X In using Tapatalk 2
              Great news! Just got it up and running! Thanks!
                Nice
                Not all the time, at least you choose perforance like the governor, (I dont suggest it cause the stick will overheat)
                My devices:
                Gearbest.com)
                  Ok , i will install setcpu to see.
                    OK, so I installed the 1080 version, after having 1.7 previously, and all seems OK. Few comments though:
                    a) Boot image was set to 1080, but a small centered image was shown (Android dude), not a full screen one like old 1.7 ROM - is this OK, or did I mess up?
                    b) If you do install 1080 version, remember the FONTS will be VERY SMALL. Not something I had thought about, and really noticed having used the 1.7 version previously. I altered the settinngs to HUGE font, bold text, etc, and it made a small difference, but things like clock in bottom right are TINY. This is a trade-off for having 1080 I guess, but have a think about it before deciding which to flash - I may reflash with 2.1 720 version just because of this. Anyone got any ideas to improve this?
                    c) Tiny request to Bob - can you adjust the WiFi name to something useful, like Android MK808, so that when checking router settings I can see which devices are which, rather than seeing "
                    android_8748932e6478debc
                    " or similar - silly Android issue that you still cannot set WiFi name easily in UI!
                    d) Strangely Dice Player now runs, with SW encoding active not tired to look a HW yet. Previously it just said "Sorry cannot play this video". Not sure why it would now be running, as Rockchip is still listed as unsupported!
                    e) Streaming with FilmOn (live TV streamer) seems jerky with audio sync issues, as others seem to mentioning with NetFlix
                    Other than this ROM seems fine, and runs quick enough for me. As I say, will probably keep 2.1, but drop to 720, just to be able to get a better 10 foot view!
                      When you use titanium backup or other programs ( I use Rom toolbox pro) you can backup the app and the app datas. But usually those aplications have his own data saver.
                      Thanks again and I will check it out.
                        Cannot upgrade.
                        Anyone help me. I've just bought one and I decided to upgrade it to 4.2.2. The PC did recognize MK808 and had correct driver. The flash tool said "Found RKAndroid Mass Storage Usb" but every time I click Reboot to flash mode then it failed. It said something like "no supporting.." or "this is not a msc device" I don't remember exactly. I also used alternate reboot to flash but it didn't work. What can I do?
                        I'm using Windows 8. First time I thought It was because of Windows 8 but I didn't get the flash tool work on Windows 7 too.
                          Use the manual method I also describe! Hold the reset button in and while holding it, plug in the USB cord to the PC. MK808 will boot into flash mode and flash tool should say "Found rock loader USB"
                            install driver for win8
                            Hi,you have to install driver for win 8,then reboot win and it work,good luck.
                              My wifi is not working
                              Upgraded to 21 and my wifi connects and then disconnects repeatedly
                                same problem here; it also happens on factory 4.2.2.
                                went back to 1.7 for now; hope wifi compatibility improves when the next version is released.
