MK808/MK808B/MINIX Hybryd FW V2.2.4 !NEW!(22.05.2013)
    This is modified Minix Neo x5 firmware with my tweaks.
    If anyone have question just ask
    !Google TV Apps Can Be Downloaded From My Website!
    My website:
    www.apkfreak.com
    Facebook:
    https://www.facebook.com/Apkfreak
    Rockchip Batch Tool
    Beta:
    MK808
    Dev-Host V2.2.4 720p
    Cloud FreakTab V2.2.4 720p (Mirror)
    MK808B
    Neo G4
    Neo X5
    Stable:
    MK808
    Dev-Host V2.2.3 480p
    Dev-Host V2.2.3 720p
    Dev-Host V2.2.3 1080p
    MK808B
    Neo X5
    Neo G4
    Cabletech
    CWM
    Available soon...
    NFS Kernel (Android 4.1.1):
    Dev-Host
    FreakTab Cloud (Mirror)
    I cant test this kernel becouse my mk808 was swiming in water so please post fedback on what devices its working and on which its not working.
    Post abouth wifi etc. it will probably work on RK901 wifi chip devices.
    If this kernel dont work for you, you can always go back to stock without loseing any data.
    Use bob tools to flash just the kernel.
    You can mount NFS share using Busybox, just download any terminal app and paste this command (edit remote nfs directory to look something like this 192.168.x.x:/xxx acording to your NAS nfs share IP):
    Code:
    su
    busybox mount -o rw,intr,soft,nolock,nfsvers=2 [remote NFS directory] [local directory]
    To Mount at system startup you can use a init.d script or add a code abowe to /system/etc/install-recovery.sh file.
    It will mount to /system/mnt/NFS you need to edit script to add your shares (Use Notepad++)
    Script:
    Dev-Host
    MK808 USB BT Kernels:
    Dev-Host 720p
    Dev-Host 1080p
    Modules RK3066:
    Dev-Host
    Code:
    rtl8711.ko; nls_utf8.ko tun.ko; ath3k.ko; hci_vhci.ko; bfusb.ko; bcm203x.ko; btmrvl.ko; btmrvl_sdio.ko; ath.ko; plusb.ko; pl2303.ko; gspca_main.ko ;gspca_sonixj.ko; sunrpc.ko;
    auth_rpcgss.ko; lockd.ko; r8712u.ko; mcs7830.ko; rt5370sta.ko; rtl8192cu.ko; cp210x.ko; ftdi_sio.ko; nfs.ko; ntfs.ko; 8723au.ko; cx82310_eth.ko; dm9601.ko; smsc75xx.ko; smsc95xx.ko
    changelog:
    V2.2.4
    -based on 20/05/2013 firmware
    -rooted with latest SuperSU
    -aded:
    MK808 1920x1080_24 (only 2dark4you kernel)
    Neo X5 1920x1080_24 1920x1080_25 1920x1080_30
    -nfs support only on Neo X5
    -applied new set of FFMPEG library
    -updated libstagefright library
    -support the new Gen.2 RKremote controller app
    -added RKGameControlSetting for game touch profile setup
    (external install, if you want it install eHomeMediaCenter_box and RKGameControlSettingV1.0.1 on your device and RKRemoteControlGeneralCastV2.0.2 on your phone)
    -fixed some strings in Settings and firmwork-res for better look.
    (example: was "fast", now "Fast")
    -visual changes (wallpaper, status bar, pointer, shoutdown menu)
    -init.d support
    -seeder app to speed up things (entropy generator)
    V2.2.3
    -bug fixes
    -fixed 2dark4u kernel support (if you want you can flash alex kernel now)
    -init.d support
    -separate modules
    (now only btusb.ko; cifs.ko; md4.ko; xpad.ko; virtual_touchscreen.ntts.ko are loaded at startup)
    -modules package
    (if you want tu use any of additional module, just extract the "Modules RK3066" package
    chouse module you want to be loaded at startup, rename it to "custom.ko" and put it in the root of internall sdcard
    it will auto load on next boot.
    you can put up to 3 custom.ko (custom.ko; custom1.ko; custom2.ko)
    -fixed wifi for mk808 (becouse of thease i need to create separate .img for mk808/mk808b)
    -usb bt for mk808 will be optional (if you want usb bluetooth support flash USB BT Kernel using rktools or finless tools)
    V2.2.2
    -better performance
    -faster boot up
    -youtube for gtv updated to 1.6
    -tv launcher
    -build.prop fixes
    -fixed touch emulation
    -new modules loaded at startup:
    Code:
        8723au.ko
        cx82310_eth.ko
        dm9601.ko
        smsc75xx.ko
        smsc95xx.ko
    V2.2.0
    -NeoX5 +NeoG4 Support
    -based on 26.03.2013FW
    -rooted
    -build.prop changes
    -gameloft games fix
    -logitech C series webcams best suport
    -virtual touchscreen suport (apps like sixaxis can mapp touch events, degre need to be changed to -90 in sixaxis settings)
    -usb bluetooth dongle support for mk808 (working randomly)
    -new bootanimation
    -stock kernel (you can flash any other kernel but bluetooth dongle will not work anymore)
    -app space 2gb
    -more space on launcher screen
    -cifs auto mount on startup (edit /system/etc/install-recovery.sh and put there your server ip, username, etc. change permisions to rwx --- ---)
    -libstagefright.so (new for better xbmc and other players compatibility)
    -youtube for gtv
    -wallbase (tons of nice wallpapers)
    -(1080p) LCD Density 240
    -(480p) fast as hell;p for thous that dont need hd
    -added Android Tuner
    -build.prop tweaks (wi-fi, ui, and other tweaks)
    -es explorer (manage your files with best file manager, auto apk install)
    -deleted useless aps
    -fixess i dont remember;p
    -modules loaded at startup:
    Code:
        btusb.ko
        xpad.ko
        md4.ko
        cifs.ko
        rtl8711.ko
        nls_utf8.ko
        tun.ko
        ath3k.ko
        hci_vhci.ko
        bfusb.ko
        bcm203x.ko
        btmrvl.ko
        btmrvl_sdio.ko
        ath.ko
        plusb.ko
        pl2303.ko
        gspca_main.ko
        gspca_sonixj.ko
        sunrpc.ko
        auth_rpcgss.ko
        lockd.ko
        r8712u.ko
        fakeinput.ko
        mcs7830.ko
        rt5370sta.ko
        rtl8192cu.ko
        cp210x.ko
        ftdi_sio.ko
        nfs.ko
        ntfs.ko
    install:
    -unpack arhive (anywhere)
    -start RKBatchTool.exe
    -put mk808 into flash mode (pres hiden buton and conect mk808 to pc, use usb otg port)
    -instal proper drivers when windows ask (drivers are in \Rockchip_Batch_Tool_v1.5\Rockchip_Batch_Tool_v1.5 \RockusbDriver)
    -when you wil see number 1 in green box selec "..." button in right top corner of RKBatchTool
    -navigate to MK808 Hybryd FW V2.1.2.img
    -pres restore button in RKBatchTool
    after instal:
    thats the things to do aftrer yoy install your rom o mk808.
    -first bootup will be slower then the next one (android is setting ui)
    -after boot wait about 3-5 minutes and reboot the device
    -go to settings>developer options:
    -change all animations to 0.5x
    Thanks to:
    -2dark4u
    -finless bob
    -kizs
    -minix
    Everything is possible if we work together!
    ApkFreak
    In v2.2.3 my recommended Ethernet2USB adapter (from dealextreme) didn't work at all and there's no problem on Finless 1.7 and 2.1 (work by default).
    Could anyone confirm the same for v2.2.4?
      Not sure which one you have but I am using SKU: 170753 from DX on v2.2.3 now and it works perfectly.
        Download link broken?
        No luck downloading for MK808B V2.2.4
        Tried with Chrome and IE.
        Just me?
          its should work later.
          its something with dev-hot
          ApkFreak
            Thank you for this ROM.
            I have one question :
            What advance taskkiller do you mean?
            -in advance task killer
            -in advance task killer go to settings:
            1. check startup kill
            2. select startup delay and set it to 20-30s
            I installed the version from Rechild and there is no option : "check startup kill" .
            Is is something build in your ROM or is it something from Google play store?
            sorry i didnt updated that part of instal process.
            there is no advance task killer so just skip this part.
              there is no advanced task killer so just skip that part.
              ApkFreak
                the rom 2.2.4 appear fine. Only youtube is not working ok. the image appear strange on youtube.
                Any one with the same behaviour?
                  Test result V2.2.4 + 2dark4u 720p kernel.
                  My setups :
                  1x MK808 with standard cooling + 2(real)A power supply.(non-chinese)
                  1x MK808 with modified heatsink + USB hub with 2.2A charging outlet.
                  USB/LAN adapter (random ****, white plastic).
                  RC11-Air mouse.
                  500 Gb USB disk.
                  For this test I used my standard cooled MK808.
                  No external micro-sd card.
                  SetCPU set on performance 1,4Ghz.
                  full!screen app.
                  MK808/MK808B/MINIX Hybryd FW V2.2.4 !NEW!(22.05.2013).
                  2dark4u kernel 720p.
                  First I benchmark 3 times, then I reboot and then I benchmark 3 times again.
                  Antutu :
                  10582 / 10631 / 10536 / 10717 / 10704 / 10779.
                  SD card read/write :
                  7.3-5.7MB/s, 6.6-9.5MB/s, 8.3/6.3MB/s, 6.9/>50MB/s, 6.8/20.5MB/s, 10.6-20.5MB/s.
                  RAM : 1702
                  CPU integer : 1889
                  CPU float-point : 1555
                  2D graphics : 1495 (1280x720)
                  3D graphics : 3251 (1280x720)
                  Database IO : 560
                  SD card write : 73 (7.3MB/s)
                  SD card read : 57 (5.7MB/s)
                  CPU frequenty : 1416MHz(x2)
                  54°C after 6 antutu benchmarks. (cold start) (measured through the holes in the plastic above the heatsink).
                  Epic Citadel - version 14 May 2013 update [gives lower score!] (High quality) :
                  (Sound does not work correct for me in Epic Citadel with this ROM, in Finless 1.7c+1.5beta1 sound does work correct).
                  42fps / 41.4fps / 41.5fps / 42.4fps / 41.7fps / 40.6fps
                  66°C after 6 Epic Citadel benchmarks. (after warm start and after 6 antutu benchmarks) (measured through the holes in the plastic above the heatsink).
                  Linpack for Android :
                  Single-Thread : 55.889 / 56.644 / 56.644 / 56.606 / 56.606 / 56.644 MFLOPS.
                  Multi-Thread : 92.981 / 92.776 / 91.816 / 92.471 / 94.703 / 95.508 MFLOPS.
                  55°C after 6 Epic Citadel benchmarks, 6 antutu benchmarks and 12 x Linpack (measured through the holes in the plastic above the heatsink).
                  XBMC :
                  Playback H264 23.976fps 1280x720 (60hz)
                  cpu0 18 - 35%
                  cpu1 16 - 38%
                  No frames dropped.
                  Framerate when IDLE in system/systeminformation - +/- 80fps
                  When XBMC is running IDLE it seems XBMC does not lock its framerate so it rockets to +80fps and the temperature rises above 61°C so when IDLE the MK808 gets warmer than when playing movies for hours.
                  conclusion :
                  This new hybrid ROM works very well, benchmarks are very consistent.
                  Performance and temperature is about the same as Finless 1.7c.
                  I will have to test some more with this ROM but my first conclusion is that this ROM is fast and stable and works good with 2dark4u kernel.
                    Thanks for the rom and the efforts! I'll test it out!
                    Is it possible to get the apk of the old explorer? I like the old one more then es file manager. I can't find my usb stick on es file manager :s
                      Originally posted by CannaBioD View Post
                      Did you tried youtube? Im with 1080p kernel.
                        I did try Youtube and I had no problems playing various content.
                        I use a 720p 2dark4u kernel and set Screen/HDMI Mode/1280x720p-60 ).
                          ok. I have huge delay on sound and video in youtube with 2.2.4 and 2Dark4u 1.4 1080p. I'll try other kernel.
                          thanks
                            with 1080p you may have some problems.
                            go to developer options and disable hw overlays
                            ApkFreak
                              I tested my mk808 with Finless 1.7c + 720p2dark4u kernel and it was much faster in Epic Citadel than V2.2.4 + 720p 2darku4 kernel.
                              1.7c + 2dark4u kernel scores average 54fps. (SetCPU 1,4GHz, performance)
                              V2.2.4 + 2darku4 kernel scores average 42fps. (SetCPU 1,4GHz, performance, noop)
