MK808/MK808B/MINIX Hybryd FW V2.2.4 !NEW!(22.05.2013)
CPU speed
Hi there!
I have MK808b with this ROM installed (v2.2.4) and the CPU has a maximum speed at 1GHz (checked with SetCpu app, even if is set to max 1.6GHz). This device has a dual core CPU at 1.6GHz..why I can not use the full CPU speed?
Is there any ROM that use the full CPU speed?
Thanks, Razvan.
The CPU speed is limited in the kernel.
You can try to overclock your kernel using this tool: http://www.freaktab.com/showthread.p...rk3066-kernels or if you don't mind loosing WIFI you can flash a custom mk808 kernel like 2dark4you or kizs kernel.
But if you ask me, there is a reason that the CPU speed is limited. I never managed to run the mk808b on higher frequencies that 1.2 ghz without instabilities.
I know that the stick is advertised as 1.6 ghz dual-core, but if you ask me, this is pure fraud.
There are currently 1788 users online. 0 members and 1788 guests.
