MK808/MK808B/MINIX Hybryd FW V2.2.4 !NEW!(22.05.2013)
    This is my favourite Rom to use, and now the manufacturer went and changed the Mk808B !!
    Any chance this is ported to the new Mk808B.
    I tried porting it my self but now joy
    How to port Roms.
    New MK808B
      How to port Roms.
      New MK808B
      http://www.freaktab.com/showthread.p...W-WIFI-CHIPSET
      yes i am in same boat as you... please lewy save us, I love your ROM and want to keep using it!!
        How to port Roms.
        New MK808B
        Why would you want to run an Android 4.1 ROM on a device that runs an Android 4.4 ROM?
        KitKat already has more than 70% of improvements that this ROM has.
          There is a kitkat 4.4 with ap6210 rom????
            I'm a little lost with the kitkat stuff as I've never used it before until the other day. I love how Lewys rom has the auto hide system bar feature. Does Kitkat have this or is it set to run off startup and auto hides the system bar upon entering xbmc? This new version of the mk808b is making me lose my mind.
              KitKat has immersive mode.
              As soon as you run an app, it goes fullscreen, hiding the status bar.
              You can then bring up the status bar again or hide it with swipe up/down while in fullscreen.
              It can even be set on per app basis, so only certain apps hide the status bar.
              There are KitKat RK3066 ROM's for MT5931,RK901,RTL8723 currently and easy to adapt to AP6210,RTL8188 also.
                hi mo123, where i can find KitKat RK3066 ROM for MK808 with RK901 wifi chip?
                Many thanks in advance
                  I'll finish my custom ROM and upload it this weekend.
                  I also have bluetooth working for RK903 wifi chip so far and will try more tests to also make this wifi work, there is already RK903 wifi working on MiniX Neo X5 but not MK808B TV Sticks.
                  Since I have a MK808B(RK903) I want to make the ROM work with both wifi chips, so everyone can use 1 ROM. Can you PM me a dmesg with GPIO dump for MK808 to compare MK808/B?
                    i used your awsome media center rom and i'd change to your kitkat rom. since i run linux with olegs 3.0.36 on the mk808b as well i want to make sure that it is running on your kitkat as well ?
                    thanks for all your efforts.
                      Hi
                      Will the Minix rom work flashed with Shomaris 409j o/c kernel
                      Ed
                        No, because this rom is Android 4.1 and the kernel is for 4.2.
                          Thanks Phinc
                            Hi all, i hope its right place to write this info
                            so my device is mk808b original
                            I flashed the device with MK808B_MinixHFW_2.2.3_1080p.img
                            I have following problem:
                            I use lan card, i mean usb to lan, in Android settings i set up static ip adress, when the system boot the android icon for lan , lan itself is not working.
                            It works only when i go to the settings and restart lan network switch.
                            I hope we can debug this problem.
                              Known problem. Use the Ethernet fix mentioned here: http://www.freaktab.com/showthread.p...ers-read-this)
                                I installed 2.2.3 720p on my mk808 it works nice except my wifi. wifi is working but it works very slow.
                                is there something I can do about it!?
