MK808/MK808B/MINIX Hybryd FW V2.2.4 !NEW!(22.05.2013)
"Directory bind" install app on SD card
Hi Lewy
I try to use app called "Directory Bind" on your MiNiX Hybrid ROM to install more games on SD card but not quite success. I see you have this app on your ICS ROM so you should have experiences with this app. Can you confirm this Directory Bind app work on this MiNiX Hybrid ROM?
Thank you
Just this:
-Added 5.1 channel HDMI PCM multi-channel audio (NOT HDMI passthrough)Everything is possible if we work together!
NFS (Test) Kernel in first post.Everything is possible if we work together!
I am not aware what is PCM. I searched also on google but all are so much technical info I couldn't understand or relate with our TV sticks.
To be precise and be simple, my requirement is...
I have MK808. Hence, output are HDMI, USB and mini USB.
How can I make home theator system with 5.1 channel out?
If anybody has such set-up, please share.
it will probably work but you will lose wi-fi and bt:"Everything is possible if we work together!
any. there is option in android settings->sound.Everything is possible if we work together!
"NFS" google it.
Its stock G4 kernel with nfs module.Everything is possible if we work together!
There are currently 1592 users online. 0 members and 1592 guests.
