[ROM] Unofficial OpenELEC for MXIII-G & Tronsmart MXIII+
Question bit related to openelec bit to Kodi. When skipping video inside openelec(6.0.3e and 7beta))(box connected to denon avr) i see black screen for few sec(like out of sync), when doing the same inside android+kodi 16.x all is fine same as box connected directly to tv.Any way to fix it or anyone have the same problem as well?Last edited by loki7777; 23 June 2016, 15:43.
Originally posted by hscotty55 View Post
That is a clone box! That is what you guys get for buying them cheap from Amazon. When will people learn!!Last edited by eprom101; 26 June 2016, 20:01.
Originally posted by kenmills View Post
Hey eprom101,
Yeah sadly I had one of those boxes also. It WOULD NOT flash or work with any of the ROMs. Tuns out it was completely the wrong chipset as advertised. I got it cheap on Amazon and it was a knockoff. To confirm, you need to crack open th case and pop off the heatsink to see what the exact chipset is.
Cheers,
Ken
Originally posted by Doggyofone View Post
I have installed extfsd to be able to explore the sd card in Windows. However, I don't see the "update" folder. All I see is aml_autoscript, kernel.img, kernel.img.md5, system and system.md5. I can't explore any of them to find sub folders. How/where do I find the "update" folder?I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
Ron White
if i want bluetooth on my MX3G box do i have to go back to android system again i love OpenELEC on my box but i also have a game controller that i like to use again i wanna install RetroArch into my Kodi/OpenELEC
i would love to play the old shcool games on my big tv
So sorry i have read now that bluetooth are working in the 6.something anyways i have installed the newest test one and will test it out hope to get gaming soon but if anyone also had trouble with their bluetooth and got it fixed please reply here what you did
CyberViking out........Last edited by Darkzide; 28 June 2016, 15:40.
Hello.
I wanted to install Openelec 6.0.3e with toothpick install, but after a Wipe and Factory Reset, I got an install error with each file I've downloaded.
I've tried to install Openelec through SD card and it works ... is there a way to fix the problem?
I've Mx3-G 2Gb and I'm usign TWRP 2.5.0.0 K200 ... thank you!
hi,
i tried flashing your file (openelec 6.0.3,openelec 6.95.2,librelec 7.0.1)
but no luck
i used zip file,and flash via toothpicking
after i select file zip(on update ext)
its always said
e:footer is wrong
e:signature verification failed
installation aborted
can anyone help?
whats wrong in my step?
or do i must factory reset first than flashing?
thanks before
I'm running LibreELEC-MX3G.arm-7.0.1.4.zip on a MXIII-G with 2gb ram and I having some buffering issues on larger files (5gb and up) from my NFS shares over WIFI.
Would manually mounting my NFS source help to fix that like mentionned here http://forum.kodi.tv/showthread.php?...855#pid1953855 ?
And if so, how would a simpleton like me go about doing that on LibreELEC ?
There are currently 1624 users online. 0 members and 1624 guests.
