[ROM] Unofficial OpenELEC for MXIII-G & Tronsmart MXIII+
Hello.
I wanted to install Openelec 6.0.3e with toothpick install, but after a Wipe and Factory Reset, I got an install error with each file I've downloaded.
I've tried to install Openelec through SD card and it works ... is there a way to fix the problem?
I've Mx3-G 2Gb and I'm usign TWRP 2.5.0.0 K200 ... thank you!
Originally posted by hscotty55 View Post
Installing from the toothpick method is not updating. It is doing a fresh install. The update is done by placing the files in the update folder via PC.
Would it be possible to add 2 things:
1. the second phisical lang keyboard selection (like i openelec progrmas) so I can define a second lang
2. The unoffical addons, so i can install vnc
This is ofcourse for the libreelec 7 version (zip file install on nanad)
Now I see the openelec version also does not have these 2 things, How can we get access to them?
another question:
If I want to do this:
http://openelec.tv/forum/105-keyboar...-request#31349
How can I do this with this build???
be able to support switching between 2 physical keyboards on screen, it need xorg and also
setxkbmap -display :0 -layout us,ru -option "grp:rctrl_toggle"
I checked this on an intel machine running OE (not amlogic this version) and it changed my keyboard lang.
PLEASE PLEASE PLEASE helpLast edited by alon24; 15 June 2016, 19:23.
Wilro,
After going through several variations of the MXIII-G it looks like they are now shipping the MXIII-C board with 202L1 firmware. This board is not compatible with previous firmware and only flashes with M8S+ firmware. I noticed Bruur's post on how he recovered from brick and tried a stock firmware for Acemax M8S+ burn from PC via Amlogic USB Burning Tool. This worked well to recover and is just an FYI for others with this box...
I then flashed via toothpick Openelec from http://amlinux.ru/image/ and Im running OpenELEC-Amlogic.arm-M8SPlus-6.95.1.1 with all hardware recognized and working well. The box is just as fast as the previous MXIII-G but it does run cooler and doesn't get warm to the touch.
I'm not sure if you want to make a version of OpenElec for this version, I just wanted you to know about the differences and that it is a good piece of hardware... IMO
I'm willing to test for you if you are...
Frank
Originally posted by MinixCrazy View PostI then flashed via toothpick Openelec from http://amlinux.ru/image/ and Im running OpenELEC-Amlogic.arm-M8SPlus-6.95.1.1 with all hardware recognized and working well. The box is just as fast as the previous MXIII-G but it does run cooler and doesn't get warm to the touch.
Also, I'm also up for testing! New boxes indeed all come with 201L1 firmware and Netxeon MXIII-C_V1.1 written on the mainboards, I even have the newest boxes underway with Netxeon MXIII-C_V1.2 mainboard. It would help to have an updated version of OpenELEC or better: LibreELEC for these newest model MXIII-G 2GB/16GB boxes!
wilro_6276 any thoughts about adding support for 2 keyboard langs (phisical keyboard) in setting so I can do a script to change phisical layout?
I'm up and running dual boot with openelec 6.95.2a. Nice and fast and problem free so far. Unfortunately openvpn is not included in the build, although it is included in OE 7.0 official builds. Including openvpn in this build would helpful and very useful for those of us trying to keep things private and secure.
wilro 6276, I hope you will consider this in future builds.
ThanksLast edited by Doggyofone; 21 June 2016, 23:20.I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
Ron White
Originally posted by mazsuper View Postchange the extension of the file, should workLast edited by Doggyofone; 21 June 2016, 23:21.I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
Ron White
Originally posted by Doggyofone View PostI'm up and running dual boot with openelec 6.95.2a. Nice and fast and problem free so far. Unfortunately openvpn is not included in the build, although it is included in OE 7.0 official builds. Including openvpn in this build would helpful and very useful for those of us trying to keep things private and secure.
I followed the instructions on page 1, booted and LE installed. I checked the build via ssh using putty and found the openvpn bin where it is supposed to be in /usr/sbin. I installed VPN manager from here: http://openelec.tv/forum/unofficial-...n?limitstart=0
and setup my service. I now have a working openvpn.
As I found, the pre version 7.0 OE/LE builds do not have openvpn pre-loaded, so you have to install 7.0 builds.I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
Ron White
Ron White
There are currently 1784 users online. 1 members and 1783 guests.
