Ken
[ROM] Unofficial OpenELEC for MXIII-G & Tronsmart MXIII+
Hello.
I wanted to install Openelec 6.0.3e with toothpick install, but after a Wipe and Factory Reset, I got an install error with each file I've downloaded.
I've tried to install Openelec through SD card and it works ... is there a way to fix the problem?
I've Mx3-G 2Gb and I'm usign TWRP 2.5.0.0 K200 ... thank you!
Originally posted by ilfrance View PostHi wilro, latest libreelec has a problem when using 4K resolution, previous build was fine. I've attached a picture to explain the problem
OK, looks like we still need the kodi 4k patch from wetek_core (I was hoping that kszaq 's latest kodi patchset would eliminate this need- I have no way of testing 4k personally, & my TV's work equally well with or without the patch
Originally posted by kenmillsGood day!
I first want to say a huge thanks to everyone involved in these ROMs, especially Wilro! You have a PM mate. :-)
Second, I would like to see if anyone has any recommendations, as I can seem to get either the OpenElec 6 or 7 builds to load on my TV box.
I have a Tronsmart MX3+ 2gb/8gb
I tried the MX3G.arm-6.0.3e, and the MX3G.arm-6.95.3a and I get the same result:
It boots up, I get the openELEC logo, and then it goes to a blank screen. I have tried going into the botloader and wiping data, but it still gives me a blank screen after the OpenElec logo.
The LibreELEC-MX3G.arm-7.0.1.2 boots up fine.
I would prefer to use OpenELEC as I have used them for a long time now, since early days.
Thanks in advance for any advice you may have.
Cheers,
Ken
OK, this seems rather weird, as my 7.0.1.2 build is the *only* recent build I've released that lacks kodi's 4k support patch, & this needs to be applied @ build time - I suspect that for whatever reason, kodi isn't detecting the correct resolution of your TV (or your device's bootloader is reporting the incorrect resolution of your screen to kodi ;( - Are you using the hdmi cable that the device was supplied with?
OpenELEC hasn't seen any updates for nearly a month now, so I will be releasing a new LibreELEC build based on my OE kernel shortly (trying to isolate a possible regression in kszaq 's latest kernel
Regards,
Wilro
Howdy All,
Due to the lack of development on OE recently, I have done a new build based on LE (7.0.1b) - This build incorporates most of kszaq 's LE patches, + my older kernel from OE 6.95.x - I will release a new build for OE when it starts getting updates again.
Personally, OE 6.0.3x works better than any of the 7.x.x for my use case
Cheers!
Hi Ken,
Regards,
Wilro
You got a PM also :-)
Cheers,
Ken
I have this error when i enter to recovery mode, i can successfully wipe data and wipe cache, but after all complete it says "E:cannot load volume/misc!" but the box is working just fine. BOX is MXIII-G. Should i be worried or its normal behavior for this box. I've never flashed my device, just updated OTA to 108L, after update i went to recovery to wipe data and cache and i saw the message "E:cannot load volume/misc!" I think device is prerooted!?, at start SuperSU says "Binary needs to be updated", i've updated "normal" and after that it reboots successfully to OS. Everything is working fine but i'm worried about this message.
If someone has the same device can you please go into recovery and see is there same error?
Do I need to re-flash 108L from SD card or?
CPU-Z info:
Model: MXIII-G (n200)
Manufacturer: Netxeon
Board: n200
Hardware: amlogic
Total RAM: 1572 MB
Internal storage: 11.84 GB
Originally posted by wilro_6276 View PostHowdy All,
Due to the lack of development on OE recently, I have done a new build based on LE (7.0.1b) - This build incorporates most of Guest 's LE patches, + my older kernel from OE 6.95.x - I will release a new build for OE when it starts getting updates again.
Cheers!
Hi Wilro,
My question doesn't have to do with the MXiiii-g. But it does pertain to OE.
Do you or anymore else know if OE works with AC wifi. I purchased a box with ap6335 AC wifi chip. I'm going to run OE on it. But the company Zoomtak said that AC won't work with OE.
I tested the box with android 5ghz with ookla app. Router upstairs and my service is rated up to 150mbps. I was able to get 138mbps wifi.
Haven't tested it with OE yet myself. But Kerber did a test on his T8V and he got up to 60mbps wifi.
What's the command in terminal to test download speed with OE. Or is there another way to test download speed with OE.
Thank You.
Thank You.
Cheers!
@wilro_6276
Why don´t you publish these builds as Community-Builds in the LibreELEC-Forum like kszaq does with his builds for the MXQ S805?
Cheers
Mark
Hello.
There are currently 3681 users online. 2 members and 3679 guests.
