[ROM] Unofficial OpenELEC for MXIII-G & Tronsmart MXIII+
Originally posted by wilro_6276 View PostHi MinixCrazy ,
This is rather unfortunate, as the original MX3-G (which I have) came with Kitkat. Another way to prove if the box is a genuine MX3-G, is to try loading the Tronsmart L106 firmware on it, as this is the rom that I derived most of the MX3G port of OE from, & as such has the greatest chance of working 100% with my builds.
It looks like the sheer variety of "MX3-G" devices flooding the market at the moment are suffering the same identity crisis that the "All Black MXQ" are. My hats off to kszaq for being able to get so many varieties of it (mostly) working with his build- He's certainly been able to delve far deeper into it than I have to date (Happy owner of 4 x "All Black MXQ" that work almost faultlessly with his 5.0.8 build - Purchased for family so that they all have a common box for me to support
Wilro, tI tried the L106 Tronsmart and many others, nothing worked. The funny thing is the box would not toothpick boot to revovery without the sdcard, it was like they didn't want the box reprogramed? The performance was very sluggish. The hardware is not even close as you can see in the photos. I played with them for two nights straight and gave up. I'm steamed because I'm certain the seller is trying to pull a fast one on the public and just wondering how many people have these clone boxes that have experienced problems with your ROM.
FrankLast edited by MinixCrazy; 23 March 2016, 03:02.
Wilro,
Just tring the new test beta 6.95.1, did a toothpick install from a fresh KitKat wipe and I'm getting similar CPU issues from some of your earlier builds, CPU2 & CPU3 are frozen not cycling like normal. They worked fine on the 7.0 test build...
Edit I was wrong, its on the OE 7.0 as well... I'm stepping back to 6.0.3b (Its working fine)Last edited by MinixCrazy; 23 March 2016, 03:03.
Originally posted by wilro_6276 View PostHello roolmapool,
With the exception of one of my older no-name TV's here (which refuses to boot when cec signals are sent to it), cec mostly works - Have you gone into your addon's (wetek hdmi cec) & enabled & turned it on? The addon defaults to being disabled on new installs to ensure maximum compatibility, & is one of the 1st things I disable when I experience TV/remote problems
Now i use your beta OE... nice so far.
Frank- I'm kind of kicking myself now that I didn't buy more of the original MX3G's, because I know if my current one dies, I'll end up with something that is the same in name only, with a whole slew of new/different problems to my current one...
Originally posted by ilfrancehey wilro, are you aware of this https://libreelec.tv new fork being born?
Howdy All,
Another OE7 test build posted HERE
This build brings "boot from Nand" option when you have booted into this build from sdcard (thanks kszaq ), so that you can boot off nand without removing your sdcard - You need to toothpick/install to update the uenv on the device in order for this to work.
There have been a few tweaks for kodi + I've changed the default scheduler back to "interactive"
I will release a new OE 6 "stable" build once I'm sure I haven't broken anything else
This build brings "boot from Nand" option when you have booted into this build from sdcard (thanks Guest ), so that you can boot off nand without removing your sdcard - You need to toothpick/install to update the uenv on the device in order for this to work.
gthebest ,,,> "You need to toothpick/install to update the uenv on the device in order for this to work."
if you have been dual booting, then its nothing new, just do toothpick/install ...well if you have not, then its a little more involved.
burn the img on a sd card first, then tookpick install.
for windows: http://wiki.openelec.tv/index.php/HO...ge#tab=Windows
today I started from sctract..
Flashed Android 5.1 stock...then flashed dual boot zip...
then on one SD have Stable 6.03b
on another SD chard have OE7 test build.
so far, working like a champ
thanks Wilro...
There are currently 5384 users online. 2 members and 5382 guests.
