the community build i am using has moved to 16 so i am using this every day.
[ROM] Unofficial OpenELEC for MXIII-G & Tronsmart MXIII+
So I updated to 6.0.3a via the tar update method. Now my Harmony remote won't work. The tronsmart remote works. I still have my remote.conf file in the config files folder. That's where I had it sitting before the update and it worked. Any ideas? Its as if openelec isn't using the file anymore.
Originally posted by stannoplan View Postthere is a version in wilro's test build folder, it seems to work ok with the only real issue for me is it fails to boot occasionally. OE7 and Kodi16. http://5.189.137.29/Openelec/MX3G/test_builds/
issue is, i was running the amber skin, so after flashing to oe7 test build, it would boot to the menus and then trigger a reboot (endlesssly). I wish flashing via the toothpick method would just completely wipe everything, is there a way?
i'm going to try to flash 6.0.1e via the toothpick method next. i really hope i haven't bunked up my box :O
Update: back to 6.0.1e. Can confirm that 6.0.3a does not use remote conf from system/.config. Wilro is this something you can possibly address? Unsure if it's also the case with the 7.0 test build as my amber skin mucked things up.Last edited by red-i; 09 March 2016, 05:27.
Originally posted by red-i View Post
tried flashing to this, as downgrading from 6.0.3 to 6.0.1 via the update method just resulted in freezing on the openelec splash screen.
Wilro, I will update and play with 7 tonight and give you feedback... Thanks Buddy...
Originally posted by MinixCrazy View Post
Hey Red, If I'm changing major revision I flash KitKat Android first then wipe the box through recovery and then toothpick flash Openelec. This has always given me a clean system base for testing. I've had a lot of random issues before I used this method and I highly recommend it...
That's actually a pretty solid idea. I'll keep that in mind when I move to OE7. Tonight i'll probably just run the update for 6.0.3b and see how that works.
Just an FYI as this is still a development build. OE v6.0.1e works perfectly.Last edited by ukmark62; 09 March 2016, 20:06.
There are currently 2321 users online. 0 members and 2321 guests.
