[ROM] Unofficial OpenELEC for MXIII-G & Tronsmart MXIII+
@wilro_6276
i have occasional blackscreen (blink) with the new build especially watching x265 video and everytime i rebooted the box it will hang need to pull off the power plug , i have MX3 2G box
regards,
kabiseLast edited by kabise; 10 February 2016, 16:33.
regards,
kabise
I'm not seeing these problems here - If 6.0.1a build doesn't exhibit these problems, then it's going to be related to the CEC updates and/or the new backported drivers. Have you tried disabling the hdmi-cec functions (under my addons, the wetek hdmi addon can enable/disable it fully). Do you have an avr device connected? Do you have any usb devices (apart from storage) attached to the device? Are you using a 4k capable TV? (I have no way of testing any of these at the momentIs your device a genuine MX3-G/Tronsmart MX3+? (There appear to be a lot of devices cropping up with almost identical specs, but have a few incompatibilities unfortunately)
**** Openelec 7.0 test build ****
Howdy Folks,
I have just uploaded a test build based on the current Openelec development branch, available HERE
* CLEAN INSTALL ONLY (I tried restoring my OE6 config, but it puts kodi in an endless loop)
* Using kodi 16.0rc3
* Enabled *most* backport drivers (some realtek USB devices won't compile)
* NOT fully optimised yet (I haven't ported most of the kodi patches to 16 yet)
* INSTALL AT YOUR OWN RISK!!
I've installed this on its own sdcard, & appears to work quite well - As the mysql database schema has changed for this new version, I have only done limited testing thus far (I will probably port kodi 15.2 to this branch, so that I can keep compatibility with my kodi 15 devices & be able to do more in depth testing
Cheers!
i tried direct connection with TV without AVR , i don't experienced blackscreen . What seem to be the problem? i have MX3G (Gearbest) and my AVR is Yamaha .
regards,
kabise
Originally posted by tjay78 View Post
Hi burimek
have you tried edited factory_update_param.aml
when you update and add the last 3 lines here
--update_package = / sdcard / OpenELEC-MX3G.arm-6.0.0.2f.zip
--wipe_data
--wipe_cache
--wipe_media
so the box is reset and as good as new...
t-j@y
i try the kzaq rom and work nice at the moment.
thanks
@wilro_6276
regards,
kabise
Originally posted by burimek View Post
i have try this methode and your new rom**** Openelec 7.0 test build **** but i have reboot bug, when i try to update my fanart from video.
thanks
The test build is bound to have problems, as it is still under heavy development, & as stated, I can only do minimal testing of it until I can upgrade all my devices to kodi 16 (I have a central database that all my devices share, which is incompatible with kodi 16). This is more of a peak at what's coming with the next version of OE/Kodi.
Originally posted by loki7777 View PostAny chance of having option to power off tv/avr like it is in raspbmc or I think even openelec on raspberry pi?And second thing any chance adding 5sec step to options?
As far as the 5sec step option, I believe that is implemented in kodi 16 - I will include it if it's available for the current stable builds.
Originally posted by Bigredfan View PostWilro
Quick question. Using your builds how would I do this. It will help me achieve better speed with some of my addons
"On openelec you can edit the boot params to move the whole /data partition to a different disk (even an SSD)"
I wouldn't recommend this, however, to do so you'll need to extract the initramfs from the kernel.img, & edit either the "platform_init" or the "init" file to change what is defined/mounted as the "data" partition.
You'd probably get better results using a faster sdcard or using the internal nand on the device (I find the usb port speed on these boxes pretty "underwhelming"
It may be possible to override the default kodi config file to point just the "addons" folder to a USB attached device (actually, this could also be achieved, in theory by just symlinking the "addons" folder to a path on a USB drive)
Just looking to maximize efficiency while not taxing the box
What about offloading some of the stuff to a MySQL database running on my desktop computer. I have heard that can help if you have multiple boxs in the same house
Just looking to maximize efficiency while not taxing the box- Unfortunately, it doesn't really help with addons, which are installed individually on each box's internal storage (my boxes are all different amlogic models, with a few PC's/tablets, so I'd expect this behaviour) - The only caveat is that you need to run the same version of kodi on all boxes, as the database schema changes with each major release (This is why I can only minimally test kodi 16 atm, as all my other boxes run kodi 15) - While mysql is helpful with large libraries (I have ~50k music/pictures/movies), I doubt I'd bother with it if I didn't have to share the library with more than one device.
There are currently 2236 users online. 2 members and 2234 guests.
