[ROM] Unofficial OpenELEC for MXIII-G & Tronsmart MXIII+
Originally posted by alon24 View PostOk,
But I do not see this version 6.95.2.a in zip version, only xz, where can I get that do u know?
If you go into the oe7 directory, you will find the zip file for 6.95.2a
@wilro_6276
Hi.
i would like to thanks for your efort with the mxiii-g
I'm using your OpenELEC-MX3G.arm-6.0.3d.zip from one week and it rocks.
I wonder if its possible for you to make de box power button to power off the box if we press it?
The box power button only power it on and don't power it off.
I know this is off topic, but how easy/difficult is it to create the .img file for OE from either the existing .zip or .tar files?
I also have a clone M8S box as well as the MXIII-G and I'm finding that all of the flashable zips from amlinux.ru/image/ for the M8S box soft bricks the device, and I have to use the USB burning tool to recover the box.
If there was an easy way to create the .img files from the amlinux.ru/image/ .zip or .tar files, then I could use the SD card method to test out the OE builds without bricking my M8S.
Thanks in advance for any advice.
I have a Windows 7 PC.
S812 CPU, 2gb ram, 8gb storage, wifi chip is AP6330. I bought it off **** here in the uk. It runs Kodi very well - plays back both HEVC and H264, but I would really like openelec on it. There are all kinds of issues with the M8S and installing openelec mentioned on the 'net.
At least I can get TWRP installed, backup my current system and data and restore if necessary, but I would really like to install openelec via SD Card - it would save a lot of time.
Originally posted by vn800art View PostFirst report: MXIII Plus ( old Beelink model ) => SUCCESS ( for the large part ): 6.0.1A ! All networks working, blazing fast! BT turns on but doesn't find anything. Remote works only for resume from stand by - light on the device remains BLUE even if OE has shut down ( no Red light doh ! ). I charge a large wizard and system is snappier than my NVIDIA SATV ! As I had used aml.script for the previous test, recovery refused to work this time ( no usb working, mose and Logitech k400 dead ! ), so I unplugged and replugged AC, OE started after the second boot ( just like the first time with release 6.0.1e and toothpick method working ! ).
Coming back soon !
Edit 1 : 6.0.1D: no WiFi, no BT working as before, remote works only as before, light becomes RED if in suspend !
More to come
Edit 2: 7 devel from 1/3 ( today !) only Ethernet working ( well, must say ), no Wifi, Bluetooth works and hold connection, but I haven't find a way to make it play from TV loudspeakers or send smtg outside ! Stock remote work as before, RED light comes out when shut off.
Edit 2/a : I have seen You put aml.autoscript in the file, but OE booted without toothpick method!
Thanks again for Your work, Wilro !
If You want me to check something I can test in the mornings ( Central European time, btw ) , much easyer than in the afternoons !
Alessandro
Edit:
Do not quote my remarks about recovery, once you have aml.autoscript working, and you do not need to upgrade it, it doesn't flash a second time. This was clear to me afterwards!
hey wilro, an update on those very high bitrate files: they work flawlessly! seems the problem was in the network disk being to full, i've cleared some space and i was able to watch the whole movie without any interruption. These boxes with your openelec builds really are the perfect media boxes for my needs.
So I have the tronsmart MXIII-Plus 2/8M, and I managd to burn (using Toothpick) the 6.95.1 version , but when I try to do anything from sd card, it does not mount it, it says it cannot mount . so i cannot use any zip version.
Should it be working out of the box, or how can I fix the SDcard mounting so I can flash it from SDCARD.
Also another issue I see,
I use a KVM amd it can see it ok, if its conneced (OE 6.95.1) but when I switch to my other computer and back it does not get a lock on the screen, meaning it just hangs (I did notice that if a movie is playing, it plays on my screen (connected to kvm) in slow motion.
Has any1 expreinced this?
I did not check yet without the KVM.
Hello. I would like to ask if I can change the HDMI output for my MXIII-G, so I have 12 bit color. My tv Samsung has an option for HDMI black level to change it from normal level to low, but when I connect my MXIII-G to my tv this option not working. Somewhere I read that it must changed the HDMI output from RGB to YCbCr, or change the RGB levels from 0-255 to 16-255 (I'm not sure). Can you fix it wilro_6276?Last edited by gthebest; 19 April 2016, 17:14.
Originally posted by alon24 View PostSo I have the tronsmart MXIII-Plus 2/8M, and I managd to burn (using Toothpick) the 6.95.1 version , but when I try to do anything from sd card, it does not mount it, it says it cannot mount . so i cannot use any zip version.
Your sdcard should work & mount automatically (I run from sdcard mostly, however when I reboot from nand, it always mounts the sdcard without issue) - I would try a newer build than 6.95.1, it has quite a few quirks that have been resolved in my later test builds. As it stands, there are a number of issues with kodi 16 as well which I'm unable to resolve to my satisfaction at the moment, so I'm back on 6.0.3x until I have more time (or more updates for it appear
Originally posted by gthebestHello. I would like to ask if I can change the HDMI output for my MXIII-G, so I have 12 bit color. My tv Samsung has an option for HDMI black level to change it from normal level to low, but when I connect my MXIII-G to my tv this option not working. Somewhere I read that it must changed the HDMI output from RGB to YCbCr, or change the RGB levels from 0-255 to 16-255 (I'm not sure). Can you fix it wilro_6276?- There may be some options that can be manipulated @ the command prompt on the box, but I'm not aware of any at this time, sorry
Howdy All,
I have released build 6.0.3e - It has a few improved patches over 6.0.3d, + includes my backported support to use Bluetooth audio output in kodi 15.
I'm still tied up with some major work projects which will keep me away from the MX3G until at least the end of the month, I'm having too many issue's with the current OE7/Kodi 16 builds, so I have nothing new to offer atm. I did do a test build using kodi 15 on top of OE7, which does work quite well, but simply highlighted that there are still issues with both- My 6.0.3e build is more stable than any of my oe7 ones, so I will be running it until I get more time to tinker with OE7/K16
There are currently 2884 users online. 0 members and 2884 guests.
