just tried to install on my other mx3-g and getting same error as everyone else, wish we had a base install zip that could work for definite and then just upgrade to latest etc
[ROM] Unofficial OpenELEC for MXIII-G & Tronsmart MXIII+
It seems either I'm doing something very incorrect or none of these builds are working for my MXIII box. Ive only had luck getting the files to act as if they are loadin "little android at boot". After loading the 7.0.1c .zip file the MXIII just reboots over and over and over. Funny thing is the sticker lists MXII V3_1 and the board print lists MXIII 3_1. Any suggestions?
You may only view thumbnails in this gallery. This gallery has 3 photos.3 Photos
Originally posted by eprom101 View PostIt seems either I'm doing something very incorrect or none of these builds are working for my MXIII box. Ive only had luck getting the files to act as if they are loadin "little android at boot". After loading the 7.0.1c .zip file the MXIII just reboots over and over and over. Funny thing is the sticker lists MXII V3_1 and the board print lists MXIII 3_1. Any suggestions?
The procedure I'm following is to download a .zip version from the links on the first thread, extract the contents of the zip file onto a micro SD card. I do not extract the second zip file then toothpick the MXIII while holding the power button. The firmware appears to load "android animation" but all I end up with is a black screen or boot loop..........LOL
Originally posted by eprom101 View PostThe procedure I'm following is to download a .zip version from the links on the first thread, extract the contents of the zip file onto a micro SD card. I do not extract the second zip file then toothpick the MXIII while holding the power button. The firmware appears to load "android animation" but all I end up with is a black screen or boot loop..........LOL
weren't some others having issues flashing with a supposed newer version of the mxIII? maybe this is the case here?
Originally posted by eprom101 View PostThis is what the root of my SD card looks like, not necessarily that particular version Ive tried about 10 different versions with the same result. Black screen or boot loop.
there has to be something different about your device.
edit: this was the post I was thinking about:
however he had a 2gig/16gig model.
what i ended up doing was
to install twrp via play store, installed amlogic tv stick recovery from within that app,
used the twrp app to boot into new recovery as tooth picking gave me a bsod
then flashed the
''LibreELEC-MX3G.arm-7.0.1c-update.zip''
and bingo got latest libreelec,
my other box which was identical but was easier to flash as all i did was flash zip via backup app on MXiiig
please note this is the shorten version of four hours trying everything from flashing tronsmart firmware to tooth picking with both update zip and full zip to creating bootable sdcard etc....
ps i also tried flash tool with img it didnt work
Originally posted by testbit View PostJust upgraded from 6.0.1a to 6.0.3e via the usual toothpick install. This time however OpenElec hasnt retained any of my previous settings and seems to be fresh open elec install now... anyway to restore my previous configurations? :/
None of the methods worked for me except for one flash build by justmeroms "OpenELEC-AmlMedia.arm-M8S-6.0.0.4" BUT NO F'ING bluetooth or remote. The box I have says MXIII 4K on it so its quite confusing that none of the MXIII flashes work. So I guess Im stuck with android 4.4.2 ARRRRRAARRARAhhhh?!!!!!!!!
Originally posted by eprom101 View PostNone of the methods worked for me except for one flash build by justmeroms "OpenELEC-AmlMedia.arm-M8S-6.0.0.4" BUT NO F'ING bluetooth or remote. The box I have says MXIII 4K on it so its quite confusing that none of the MXIII flashes work. So I guess Im stuck with android 4.4.2 ARRRRRAARRARAhhhh?!!!!!!!!
Yeah sadly I had one of those boxes also. It WOULD NOT flash or work with any of the ROMs. Tuns out it was completely the wrong chipset as advertised. I got it cheap on Amazon and it was a knockoff. To confirm, you need to crack open th case and pop off the heatsink to see what the exact chipset is.
Cheers,
Ken
There are currently 2076 users online. 0 members and 2076 guests.
