Have not seen activity form him in long time.
[ROM] Unofficial OpenELEC for MXIII-G & Tronsmart MXIII+
Wilro_6276....you seem to know your way around these boxes....Perhaps you can help me?
I just got a new MX3 but when I opened it up inside I found This MX3 V4.0 20151128....so far I have not been able to find the Image file for it.I did get Openelec 6.9.5.1 (AMLINUX) installed however it has NO WIFI or LAN. It is the only one that it readily Accepts and to reflash I can get M8Splus to go but only to the M8S+ logo.
Is there a fix??? Thank You for any assistance you can give!
HI there,
I hope that some one can help me.
I have an:
MXIII-C V1.1 S812/2G/16G/AP6330 (PCB 1.5mm)
Date: 2016.07.14
The software was always craching and now I can only see the red light.
I try to use the following firmware:
MXIII-C_202L1 for USB Burning Tool
I try this firmware with the following USB burning tools
AMLOGIC_TOOL_setup_v2.0.5.15_build9
USB_Burning_Tool_v2.0.6.2_build2
USB_Burning_Tool_v2.0.7_x86
When I try these USB burning tools I always get an error message like this: [0x10205004]Romcode/Lead UBOOT/Check decompress/Error result
MXIII-C_202L1 SD for sd card
I try this firmware on SD card but nothing hapen. I used the toothpick to hold down the button inside the AV port,
The above firmware i get it from here:
https://translate.google.com/transla...9136&sandbox=1
Nothing seems to work any ideas?
Any help would be aprecited.
Originally posted by cioma2 View Post
Thnk you for the help
I suppose that you are talking about the firmware: 108L1 for MXIII Plus_20160604
I try this using the USB method and the same error occour: [0x10205004]Romcode/Lead UBOOT/Check decompress/Error result
I try this firmware on SD card but nothing hapen again. I used the toothpick to hold down the button inside the AV port,
Hi
did you try the sd card boot dual boot?
Hello All! I have a problem with my new MXIII. Hopefully someone has solved it but any help at all would be great!
Here it is in a nut shell: I have tried every Image I can find and a lot of then will load in no problem BUT everyone gives me the same result....No WIFI and No LAN!
Inside the box I get MXIII Version4 20151128 This software I have not been able to locate! I am at wits end am hoping someone here can point me into a fix!
Thank YOU!!!
There are currently 2762 users online. 0 members and 2762 guests.
