Beelink M18 Amlogic S905 4K 2G/16G TV BOX 2.4G/5G Dual Band WIFI 1000M LAN Bluetooth4.0 HDMI2.0 H.265 Miracast DLNA
Originally posted by ACoster View Post
The M18_108L1 is that an official release from Beelink? It is not available for the normal update OTA.
By the way if you are on 107L1 there is indeed no OTA update to 108L1, but I recently received a device that was labelled MX64 and had firmware version 105 installed and it first updated over OTA to M18 firmware 106 and then after reboot straight to 108L1.Last edited by basjke; 03-05-2017, 17:41.
There is a NEWER firmware that was ported from the Minix U1 (fw12) and also the Ugoos AM1(fw007). They can be obtained fromCode:https://4pda.ru/forum/index.php?show...#entry58988851
Use Chrome so it can convert to english. Both firmwares can be downloaded from the top of the page on any page (click the + button to open the menu), or U1 firmware is posted on page 72 and the AM1 firmware is on page 73 I believe.
This should be much better than the 108L1 that is currently available.
Cheers
Originally posted by veronicasmithen03 View PostThere is a NEWER firmware that was ported from the Minix U1 (fw12) and also the Ugoos AM1(fw007). They can be obtained fromCode:https://4pda.ru/forum/index.php?show...#entry58988851
Cheers
From my testing, the Minix rom doesn't work as well. Unfortunately its FW version 12 and not FW version 11. Version 11 was likely the most stable.
The AM1 firmware is by far the BEST and most stable I have run on my M18/mx64/MRX box. I enjoy it much better than the stock firmware 108L1.
As for the links not working - check back every so often because I think yandex has had some issues lately. Posts on 4pda forums indicate that the download was damaged (but worked fine previously) - you will have to check the forum or test download to make sure it's correct.
Good luck.
Originally posted by veronicasmithen03 View PostFrom my testing, the Minix rom doesn't work as well. Unfortunately its FW version 12 and not FW version 11. Version 11 was likely the most stable.
Good luck.
Since this is almost 3 months ago and you haven't reported back since, I would like to ask if you could give some more feedback.
There are currently 3299 users online. 5 members and 3294 guests.
