Beelink M18 Amlogic S905 4K 2G/16G TV BOX 2.4G/5G Dual Band WIFI 1000M LAN Bluetooth4.0 HDMI2.0 H.265 Miracast DLNA
I had a bad download this works for twrp recovery and xposed https://yadi.sk/d/y9p9KpLuqJrgP. install this then flash xposed in twrp. Thanks guys
Originally posted by DoItYourself View PostAfter a long test revealed that the AC3 also not good, there remains a droputs, but much more difficult to hear.
There is no more audio dropouts, skipping, white noise, etc. - everything works fine over toslink.Last edited by DoItYourself; 04-08-2016, 08:55.
Can anyone assist....I just can't get the toothpick method to work. I want to try openelec from the microsd card. My box just won't boot into the recovery option screen. I push the button inside the av port, plug in the power (which doesn't turn unit on) push the on/off button and the unit either boots to the googleTV screen and just hangs or boots right through to the normal screen in 'safe mode'.
Do I have any other options.
There's no recovery menu on my device or I've 'broken' it during my various attempts to access it. So I can't use USB burning tool to access either. It boots OK to the stock firmware version 5L.
I can access device with SSH but issueing reboot recovery command does nothing. Do I have any options?
Originally posted by NoOne1234 View PostThere's no recovery menu on my device or I've 'broken' it during my various attempts to access it. So I can't use USB burning tool to access either. It boots OK to the stock firmware version 5L.
This should allow loading the recovery from SD if your emmc version is borked
If you can't find one
Try this one.
I think it's from 103l1 but it should still work.
OpenELEC install to Beelink M18 - mini HOW-TO
Step 1 - full install to eMMC (it will erase Android!)
Download and unzip this (full install with Kodi 16.1 RC1):http://www.mediafire.com/download/8c...0-g42ddb0e.zip
Copy the 3 files onto an micro SD card, insert it into your M18 and power on with the toothpick method.
The flash goes automatically, when finish it will reboot to openELEC.
Step 2 - update openELEC
You can flash latest update (Kodi 16.1 and more bug fix).
Empty your micro SD card, download and copy onto micro SD card this: OpenELEC-Amlogic.aarch64-M18-6.95.3-update.zip (no need unzip)
Insert it into your M18 and power on with the toothpick method, the flash goes automatically, when finish it will reboot to openELEC.
This should work well at 105L1 fw.
Anyway i did the full install from 106L1, but when finished the flash does not automatically restarted, just stand in recovery.
The remote don't work in recovery so i have attached a PC keyboard to select wipe data / factory reset then reboot system now.Last edited by DoItYourself; 05-18-2016, 23:57.
Originally posted by warlock09 View Postwould anybody recommend this new box from beelink ,im planning on buying it? thanks,,best place to buy it?would this be better than the tronsmart s95 meta?any feedback on this box pls..thankskodi,,4k playback etc...
TWRP Recovery 3.0.2-0 for the M18/MX64 from ivansemenov.Last edited by d.khomyakov; 05-08-2016, 10:04.
There are currently 2339 users online. 6 members and 2333 guests.
