Beelink M18 Amlogic S905 4K 2G/16G TV BOX 2.4G/5G Dual Band WIFI 1000M LAN Bluetooth4.0 HDMI2.0 H.265 Miracast DLNA
Yeah I will do. Rebbelul kindly sent me a link to this firmware so i may try that, as it looks closer to the m18 http://www.geekbuying.com/item/Beeli...AN-357035.html
So I've given both the tronsmart and the mini mx firmware a go with the USB burning tool. The tronsmart wouldn't even flash. The mini mx flashed OK but won't boot... It gets to the boot logo and that's it.
Now I don't know if that's down to a fault on my hardware because that's where the stock firmware didn't go further than or whether it's because it's just the wrong firmware for this device... Not that helpful really, haha.
Thanks again though rebbelul, you were very helpful and it was worth a shot!
Hi all, I nbought this Beelink M18, and I am happy about the purchase. The unit is very fast and responsive, Netflix works correctly.
Only issue so far is that a xbox360 wireless controller is not recognized, so I can't use my xbox360 wirekess gamepad. I can't test with other gamepads since I don't have any. The controller + gamepad work great on my Note 4, so the issue is in the Android box, but not sure why.
Any suggestions?
Originally posted by Catadarius View PostI've just order this box....for 60$ i think is good choice.
Can someone tell me if the passthrough works? The box will be conected to an amplifier with hdmi.
Thanks guys
Sent from my MX4 using Tapatalk
It does have in the settings the option HDMI CEC, not sure if is what you look for. I don't have an amplifier in the room to test it
Originally posted by klausita View PostHi all, I nbought this Beelink M18, and I am happy about the purchase. The unit is very fast and responsive, Netflix works correctly.
Any suggestions?
I have compiled the missing xpad driver and updated keylout for wireless 360 game controller, now plays mame great.
Originally posted by wwewwewwe View Post
http://freaktab.com/forum/developmen...rk-in-progress
Video that demonstrates the setup, show an example of the problem, the steps to solve the problem, and the working solution!!! http://www.youtube.com/watch?v=9czISrLGXNI&hd=1 So first lets just talk about the Hardware Setup. Xbox 360...
On another note, I wanted to connect a Logitech 920 HD Cam. How to make it work? (video and MIC)
I tried the fix found on xda developers but didn't work. Also I think my xbox wireless receiver is recognized as 291 (not 719) something I am missing?
http://forum.xda-developers.com/show....php?t=1792531
As for the camera, that is likely missing a driver as well, or Android does not know its a camera. Also likely missing in Bluetooth controller drivers, at least it is for me. My ipega connects, but no keys are detected no matter what mode its in (keyboard, joystick,mouse mode).
Copy/rename keymap file 719 to 219. The 219 version I thought was the wired 360 version. Android matches keymaps on USB/Bluetooth vendor Id and prod id. You will need to load/test the required module drivers as well as they are the main components missing. Load them via a term shell, make sure you have busybox, and su first, and insmod the two driver files. View them with lsmod, and view connected controller with lsusb.
Ok let see if I understood.
- Rename 719 to 219 (not 291??
- required module drivers? Can you tell me which, where to find, and where to place them
(su I know, busybox I will try to install, insmod???)
Camera works with Camera app, but not with Skype (??)
- Bluetooth is working with my earpiece and external audio box.
- Ipega is also not working??? Damn I just bought it, tomorrow are arriving from amazon. So no way of make them work???
check out the this thread for more complete details about installing/testing downloading the xpad driver:
insmod is a linux command to load kernel modules (drivers), so you want to load the following drivers/modules :
Install Keylayout
su
mount -o remount rw /system
cp Vendor_045e_Product_0719.kl /system/usr/keylayout
cp Vendor_045e_Product_0719.kl /system/usr/keylayout/Vendor_045e_Product_0291.kl
chmod 644 /system/usr/keylayout/Vendor_045e_Product_0719.kl
chmod 644 /system/usr/keylayout/Vendor_045e_Product_0291.kl
reboot
Testing out modules
su
insmod ff-memless.ko
insmod xpad.ko
it shouldn't return any errors, if it does then the linux kernel is not compatible (version differences) with the compiled modules.
lsmod will show loaded mods in memory.
Hmm, then likely skype is the issue?
I haven't really focused on it I got my 360 controller working which is better in the long run.
I'll give it another go and see, but its probably another module that's missing? Not sure if its a bluetooth one (since it does connect ok), or a joystick type one that links
the bluetooth device to joystick linux api.
Ok, thanks.
1. will try the xbox360 driver thingy tonight when back home
2. very strange that camera works but not in skype, dunno
3. will try the ipega, maybe you have a problem with bluetooth? Because so far, for me, all bluetooth devices I checked are ok.
Have you checked these files?
iPega Wireless Bluetooth 3.0 Game Controller came today off ebay half the price of others :victory: was going to use it with my android phone it also works with most phones with bluetooth and came with no drivers or software to install so easy to...
4. Other issue, I would like to listen with wired earphone in the evening (they are better quality then bluetooth ones). But the box does not have any earphone female jack.
I was going to order a USB to female 3,5mm dongle like this one
it should work? Or you have any other recommendation?
Thanks.
There are currently 2856 users online. 3 members and 2853 guests.
