NEW - Finless 1.0 ROM for S95 Telos!
    Hi Folks!
    It's been a long time since I did a ROM... Like about a year
    Took a break for a while...
    Got the S95 Telos and decided it was time to have some fun again.
    Let me tell you... Much has changed from the hacked up KitKat we had to Lillipop! I had to learn a bunch of new stuff.
    It took me almost a week in days to get up to speed and be able to really do some things in this ROM.
    So any donations would be nice especially if you like this ROM!
    __________________________________________________ ____________
    WARNING! In order to debloat and clean up this ROM I have to format /data partition and thus you will loose all your data!
    You have been warned! Please backup your stuff.
    This ROM is for the S95 Telos only! Later I may port to the Meta and Pro.
    This ROM is based off the S95 Telos 20160129 BETA ROM. I found this to be better and more stable kernel to work with.
    Install instructions:
    This is a pretty easy install but please make sure you do exactly what I list here.
    1) Download this ROM (finless_1.0_S95_telos.zip). DO NOT unzip it!
    2) Copy the zip to a SDcard. Make sure it is a good SDcard and not corrupt. If your not sure, format it FAT32.
    3) Make sure you do NOT have a recovery.img on SDcard that you used for something else. This ZIP is properly signed for the Tronsmart recovery in the box now.
    4) Go into APPs and run the Update&Backup APP.
    5) On the right side under "Local Update", click the select button.
    6) It should open a list of ZIP files on your SDcard. Select finless_1.0_S95_telos.zip.
    7) Now click the update button.
    8) The system will reboot into Recovery but will not show any menus.
    Also PLEASE NOTE: The stock ROM 20160109 had a bug with the boot logo. So your screen will be black for a while. PLEASE wait for recovery to come up!
    If you wait longer than about 1 full minute, then something else is wrong. You might have to reflash a stock ROM.
    9) The green Android man will show up and update the ROM. Do not do anything until it is finished!
    10) The system will reboot on it's own and boot the new ROM.
    Please note, this ROM takes longer to boot the first time than the stock ROM. The reason is it has be Deodex'ed. See below.
    Enjoy!
    Change Log / Features:
    1) I have completely debloated this ROM! For those that want to start clean... you have a base ROM to work with!
    None- of the pre-install APPs are there either. This includes the custom VidON XBMC. You can install that yourself if you want it.
    2) The ROM is Deodex'ed. I find that this makes the system faster.
    First boot after flashing takes longer but after that... It is much faster at booting!
    Watch how fast it boots up after reboots. Barely enough time to see the boot animation
    Also having a deodex'ed ROM allows ROM tool APPS to be able to do things like theming etc.
    3) The Google Play Store and Google Framework have been updated to the latest as of this writing.
    When you boot and login to the Play Store, nothing will need to be updated.
    4) I added back the AOSP Launcher! Now on first boot you have a choice.
    Also now in settings you will see a "HOME" item in the menu. You can use this to change the default launcher
    5) For the AOSP Launcher I added some nice shortcut buttons at the bottom. One that is nice is a quick access to the Advanced Settings menu
    6) Opened up some settings that were blocked for some reason.
    7) I fixed the SDcard write and access issues! Not just for Media either but anything!
    I tested this as much as I could so let me know.
    8) Did some small tweaking to buffers so you may see better Wifi performance.
    9) This ROM is rooted fully and properly! If you want it unrooted, use my EZ Unroot ZIP.
    10) Fixed the problem of background APPs closing.
    11) I eliminated the top Notification Bar! This is a TV box and it was annoying!
    However, you can still pull down notifications using the mouse! So it's still there just hidden.
    Not many APPs call the "Emersion Mode" so if they do not the notification bar stays. Annoying!
    This was true even with the Mbox launcher. Example, open and APP and the notification Bar pops down.
    If you do not like this, let me know and I can provide a ZIP to put it back.
    12) Added init.d script support as I do in all my ROMs.
    13) I added Xbox and Game controller KO modules. These should no be supported but I did not test it as I do not have a Xbox controller.
    My game controller I have works.
    14) Did some theming like wallpaper, boot logo, etc... Hope you like it.
    15) Some other tweaks here and there I cannot remember them all... Nothing that big just some clean up and tweaks.
    16) Finally.... This will break OTA updates from Tronsmart! It has to be this way. An OTA update from them will take away much of what I have done.
    Also I do not like the way Tronsmart implemented OTA. They force the update on you instead of letting you decide. I do not like that at all.
    I hope you enjoy this ROM.... Next release I may:
    Add TWRP recovery
    Try to fix SATA reboot and sleep issues.
    Other stuff you all report as a problem.
    ROM Download Link:
    Remember DO NOT unzip this!
    ROM -> S95 Telos - Finless ROM 1.0 (280 MB)
    Enjoy,
    Updated the change log just now. I forgot to state that I also added init.d script support.
      Downloaded, In the ears are wiggling and the gears are turning and we have a very colourful boot, its making me dizzy
      Excellent and so easy.
      Looking good snappy as
      WIFI speed excellent
      No top task bar great
      USB keyboard no error.
      One error signing into Google services stopped error, then all carried on ok
      Working very well all tests so far are good
      The only things is the Volume pop seen with Finless Rom and that's about all
      VidOn looks good,
      Bench test programs better than previous test some a few hundred (for what's that worth)
      Cheers
        What is modified to put the notification bar back. Also navigation bar. Where is it located
          Top bar is gone for good.... Pull down with the mouse and it will still pull down notifications.
          Bottom bar is like stock. If you hid it, pull up with the mouse to show it again.
          I did not ever get the volume thing pop up for me. Never saw it once.
          What is your setup? e.g. what is it hooked to etc?
            As for the volume control popping up.
            This is going to be a AML SDK issue pretty sure of it!
            Why? Because my Minix U1 box does it! I have seen it on my Minix U1.
            However I have not seen it yet on the Telos but I believe you guys that it is there.....
            Because this will be very hard to troubleshoot, we may have to wait until AML resolves it.
            Trust that Minix is also getting this complaint so I bet it will get fixed.
              Also as to the USB keyboard error.... It's there you just do not see it now.
              The reason is, you have to setup keyboard input and also believe it or not, mouse input (as a keyboard).
              Once you set these up all the way through, that error goes away.
              It is not easy to figure out all the input menu's to do this. If you cannot get it, I can post full instructions!
              Again if you do not setup ALL the keyboards you have (including the software keyboard), the error will stay there.
                No errors all good, about the menu settings for kyb and mouse might be handy to do a post just in case, no rush
                Any files for PS or XBOX controllers someone may ask.
                  Sorry i am asking for another rom where notification bar is missing and i want to restore. Just notifications would be find. In the rom i am working on bottom bar is missing and i want to restore. Trying to see where i need to change
                    Other ROM? What box is it for?
                    It may not be there at all.... Standard AOSP doesn't have it. It gets added by the TV box makers IF they even did it.
                      DAMN! I forgot to post I added that!
                      Yes I added Xbox and game controller kernel modules.
                      So yes it is there!
                      I will update the change log.
                        Change log updated to show I added game controller support.
                          Eny em95
                            Hello Bob great job for the ROM if you kindly provide the zip to the notification bar at the top to put it back, thank you!
                              Nice Work Finless,A really fast rom especially the boot time at about 17 seconds
                              Samnsung 1TB non powered HD works
                              64 GB sd works
                              128GB usb stick works
                              Logitech c270 Webcam works
                              PS3 Sixaxis Controller WORKS (This does not work on any of the tronsmart roms) So a big thumbs up there
                              Kodi running great using flumpster's Beyond installer
                              HDMI cec Works
                              Very easy to install even after getting stuck in a bootloop its still easy to reinstall to get it running again (The bootloop my fault trying to add a sensors.so flile to the system/lib/hw folder)
                              Over all a nice rom Bob thanks Keep up the good work
                              Freatab Beer Is a nice touch too
