Thanks so much for all your hard work Finless.
NEW - Finless 1.0 ROM for S95 Telos!
Hi all.. Birthday has arrived and I`ve got the Telosinstalled finless ( no issue ) but I`ve gone ahead and installed the regular Kodi from the play store. Two instances now that Kodi has locked up and I`ve had to pull the plug. Is there an issue with regular Kodi and that`s why everyone`s jumping on the Vidon one?
thanks
Happy Birthday!
Finless has a nice ROM, but it is based on a very early firmware. Many issues have been fixed in subsequent versions.
VidOn allows for HD audio that may not be available on stock Kodi versions. It has been a while since I have run the S95(Meta) on Android, so my memory as to the best Kodi version is foggy.
I have OpenELEC(balbes150) installed on it at the moment, so I can't test Android Kodi now.
Hopefully someone with more recent experience can give you better advice.
Hope your birthday wishes comes true.
Originally posted by spideymon View Postdoes anyone know if vidon will identify this box as a tronsmart vega after we uprade to finless rom and then allow the free vidon Pro upgrade?
or has anyone tried kodi vs vidon xbmx with dts hdmi passthrough (using this rom of course)...which one doesnt have jitters or sound drops?
Hi Bob a good group of people are trying to get this box up and running again they started a group to try and fix this unit as every one is sick of waiting for tronsmart to send out updates I think that you may have also given up as well but if anyone can get this box running the right way it's you I know there is never enough time for you in a day to do stuff but just maybe with the help of this group you can all get this box going here are links thanks for any reply on this Bob
link # 1
http://forum.tronsmart.com/forum/veg...n#.V_6vKL0pBAg
Link #2 starting to make new Rom
http://forum.tronsmart.com/forum/veg...6#.V_617r0pBAgLast edited by ruppert; 12 October 2016, 23:25.
Dear Bob, I am trying to restore the S95x and flash ROM -> S95 Telos - Finless ROM 1.0 (280 MB), but I download (already 4 times) the size of 270MB, not 280 as indicated in the link. Help, please, to understand. Maybe I'm doing something wrong?
My mail is [email protected]
Thanks, Regards, Zaxar
[ QUOTE=trebor;n554225]Downloaded, In the ears are wiggling and the gears are turning and we have a very colourful boot, its making me dizzy
Excellent and so easy.
Looking good snappy as
WIFI speed excellent
No top task bar great
USB keyboard no error.
One error signing into Google services stopped error, then all carried on ok
Working very well all tests so far are good
Cheers
[/QUOTE]
I'm giving you a shout cuz I'm a bit lost, I'm not sure where to look.
my first box was an M18 B link, first custom ROM was a finless creation. It was portable from his tronsmart work. Either the Telos, Vega, or Pro. It was a beautiful thing , for some reason I decided to reflash it. And use the wrong version, of course, which bricked the Box. I've decided to re-gift it, and need to revive it. But for the life of me I can't find the right wrong to run on it, from the selection above. I saw you comment on some history recently about his work ... I was hoping you could shortcut me to the version I'm looking for? Any leads? Or a way to search from where? If memory serves, the M18 portability was noted in his initial notes. Throw me a bone? Thanks!Kris....don't forget my boxes! Okay?
Originally posted by trebor View PostRule Numero Uno: all keep backups
Its all history:Kris....don't forget my boxes! Okay?
Trebor has a solar-powered server farm out back, it is housed in a Faraday cage with an oak tree growing next to it, that truth be told, could use a pruning. He has a contract with Samsung to replenish his drives bi-annually. Also has a contract with NASA to back his data up on the moon(dark side of course).
"hmm, he's in trouble then ". Nope, so far no double-naught spy has been able to locate his compound, of course I know the location, but I'll never tell.Last edited by RISCy Dude; 16 December 2019, 07:12.
trebor sure, I might get pissy sometimes...But have a hell of a twisted sense of humor.
Therefore, I be LOFLMFAO. hehe!
EDIT~ Thanks, it might be in the (yur) pile, me thinks. If not, I'll find it.
back then I think I threw the correct SD at it with no luck
Think a "pin short" will allow it to pick-up on the SD?
OR, will it need to be USB/ PC Flashed? do ya know,r want to guess?Kris....don't forget my boxes! Okay?
There are currently 1784 users online. 2 members and 1782 guests.
