NEW - Finless 1.0 ROM for S95 Telos!
    Tried 09 march edition from Tronsmart, switched back to this rom, must better, hopefully a new rom from Finless will make the differece
      can we install this rom with sd card after the latest official firmware or has to be done with pc?cause in update the box cant see the rom on sd now
        Hi Bob,Good works im on finless 1.0 & notice when i installed Apps installer for some purpose on the telos S95 it only can detect Sd card & others but not thumbdrive.
          Is touchscreen support enabled in this ROM? The stock ROM, on one monitor I tested on, doesn't seem to work with touchscreens.
            FYI, I am holding off making a ROM from this new update. It's got some issues and appears Tronsmart will be coming out with another update.
              Yes you are wise to wait. The most recent firmware is causing a lot of dust-up at the Tronsmart forum.
                Hello!
                My Telos was on bootloop and i managed to do a factory reset this morning and then i installed the Finless rom, but when i was watching a video on You tube, screen turned black, i pull the wire after some time and now i just can only get until logo of the Rom...
                any ideas please???
                I did it again and i managed to get into the recovery, so i did factory reset again...and worked, but since i am doing by luck can you tell me how can get to recovery mode?
                Again same story...when its starting to load the video, everything freezes and i am again on the finless logo.
                either my Telos is defective or the rom has bug when it comes to you tube
                  It seems this new firmware is giving more bugs then actually fixed them, like for instance the black screen when you fast forward a video or go back, I recommend sticking to Finless 1.0 Rom until updates come up.
                    True better stick to finless rom....tronsmart recent firmware still unstable at time upon bootup the device homepage just freeze need to off & on again then it back to normal ....really annoying.
                      Can i flash it via pc?
                        Finless. I installed the 1.0 ROM that you have released and noticed a few issues so far. First is I get micro dropouts on audio using the latest Kodi 16 build with HDMI passthrough set, slight skips of 1-2 seconds. Video works great and tested various files from my NAS and RAID boxes over ethernet. The second issue I have noticed is that when you are trying to scroll quickly through a list of files the box crashses frequently and then reboots. Maybe its not a problem with the firmware but a possible hardware bug. If you have any advice on fixing the audio bug please let me know.
                          I will be working on a new ROM this week time permitting
                          hi Bob,any news when you going to release The New Rom mate thanks
                            Finless,
                            Today Tronsmart has released 20160403 firmware, which what seems to fix the annoying sound passthrough and boot lock bug.
                            Could you please release a stripped down rom of this firmware, as you did with Finless Rom 1.0?
                            Thanks in Advance
                              Will do!
                                Will do!
                                Hi Bob, first of all I want to thank you for all the work you put in on behalf of us. I know this isn't the right thread for this question but I've been looking all day for one of your roms that will run on my Minix X8 PLUS. I flashed your Finless 1.1 rom but I guess it works only for the Minix X8-H PLUS and while the box works fine I just noticed I don't have any wifi. Could you PLEASE point me to the correct rom for the X8 PLUS. Thanks in advance for your time.
                                Krissy
