LibreELEC & OpenELEC for Tronsmart Vega S95
    @balbes150,
    Thanks, the remote is working, as have mentioned when I navigate movies by pressing up/down arrow continously it would not run smothly and will subsequently crash and shut down LE. I will turn on the log if that would capture the activities and post it here.
      @balbes150,
      I have attached a screen shots, just why the CPU usage is high even when there is no operation in progress, in the second screen, when I navigate by pressing up/down key continuously, the cpu usage skyrock, and some time would hanged.
      Any suggestions to cure the issues
      Debug Log hanging interminttenly and take few minins to respond
      18:20:39 T:548452093952 DEBUG: OnKey: long-down (0x100f081) pressed, action is Down
      18:20:39 T:548452093952 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
      18:20:40 T:548452093952 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
      18:20:40 T:548452093952 DEBUG: OnKey: long-down (0x100f081) pressed, action is Down
      18:20:40 T:547641913568 DEBUG: DoWork - trying to extract filestream details from video file plugin://plugin.video.emby.movies/?dbid=1949&mode=play&id=04713ca1ac5a970a5a 86e5a70c 888f6a&filename=Alpha+and+Omega+%5B2010%5D.mp4
      18:20:40 T:547641913568 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.emby.movies/?dbid=1949&mode=play&id=04713ca1ac5a970a5a 86e5a70c 888f6a&filename=Alpha+and+Omega+%5B2010%5D.mp4
      18:20:41 T:548452093952 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
      18:20:41 T:548452093952 DEBUG: OnKey: long-down (0x100f081) pressed, action is Down
      18:20:41 T:547641913568 DEBUG: DoWork - trying to extract filestream details from video file plugin://plugin.video.emby.movies/?dbid=2077&mode=play&id=5ba56f7e0efe3c2326 debca718 9f4244&filename=Ass+Factor+6.mp4
      18:20:41 T:547641913568 WARNING: CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.emby.movies/?dbid=2077&mode=play&id=5ba56f7e0efe3c2326 debca718 9f4244&filename=Ass+Factor+6.mp4
      18:20:41 T:546387087584 DEBUG: Thread JobWorker start, auto delete: true
      18:20:42 T:548452093952 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
      18:20:42 T:548452093952 DEBUG: OnKey: long-down (0x100f081) pressed, action is Down
      18:20:42 T:547641913568 DEBUG: DoWork - took 123 ms to load special://masterprofile/Thumbnails/f/f260cef0.jpg
      18:20:42 T:546375823584 DEBUG: DoWork - took 131 ms to load special://masterprofile/Thumbnails/5/506281c6.jpg
      18:20:42 T:546387087584 DEBUG: DoWork - took 152 ms to load special://masterprofile/Thumbnails/6/67a94265.jpg
      18:20:43 T:548452093952 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
      18:20:43 T:548452093952 DEBUG: OnKey: long-down (0x100f081) pressed, action is Down
      Any suggestions would be appreciated
      Cheers!
        This error is not related to LE\OE. This error is observed only in the model Telos. Users wrote that on Meta it is not. In the model Pro this is not function, ie hold the off button, the model Pro is not turned off. This error also is Android. I.e. this means that the cause is likely hardware or firmware, which is responsible for this function. In the near future I want to test one version of the fix. The chances that it will help very little, but we must try.
        At the first runs, goes setup\upgrade of the system, the scanning of the content etc. therefore, nuclei can be actively used. The system distributes load on them.
          Thanks for your support, but my device is not Telo, it is Meta, just to mention, I have three of this unit (all Meta) the issue is noticed on either Internal & External drives LE/OE, so it strange to heard it was peculiar to Telo. Or could it be that I am using incorrect firmware?
          What I observed is as soon I powered up Meat device, then launch Kodi on the system info, I noticed the CPU usage is high and consistently fluctuate without further add-on been installed in Kodi, it become so apparent when you start navigating or playing a movie in Kodi that the CPU usage skyrocket and sometimes the unit become so hot that I have to unplug the power for a while.
          To validate that I have the right firmware for my unit, could direct me to where/how to obtain the info, thanks for looking into the issue for solutions, most appreciated as usual.
          Cheers!
            A screen shot of the cpu at 40%
Name:	Kodi System.jpg
ID:	590402 Click image for larger version
              Thanks for your great work balbes150
              I installed openelec to my new telos box and it works great!.
              But, i can not turn the ssh off. Is SSH has to be turned on all the time? In the options, just have one option called "Disable SSH Password".
              I just concern about security. Because, i can't change ssh password and it comes by default like root and openelec login details. So, is this normal? Can i change that somehow?
              For secure, i choose "Disable SSH Password". Is this enough for security?
              Again, thanks for your great work.
                Just a quick one, you mentioned load cpu distributions, is this a function that i need to activate or it wasnt activated by the manufacture and it should be I am concern this may damage the unit in due cause, what is your thoughts on this.
                  As Android operating system under the same conditions of pressing buttons ?
                  I'll check again the load on the models of Telos and Pro, but previously I have not seen that critical, especially since I have not seen overheating.
                    ssh is enabled on the kernel parameters. Disable password is enough to protect a home network. If Your TV box is connected to the Internet through a router\router enabled NAT protection, then you should not worry.
                      Hi I have a MXQ pro 4K and have just got Openelec working from sd card this version S95-6.95.3. I have not used Openelec before and I have the following Problem. I cannot download any addons. I do not have Wifi and the box is connected via Cat 6 ethernet. Can anyone help with configuration advice.
                        You have the Internet doesn't work ? Addons visible in the list ? You can install Addons as files. Download the desired addon to the PC and install the TV box.
                          Thank you for your reply. If I remove the sd card and power into android I can install addons. Power down and boot from card go into kodi system file manager and try to install any zip file I get " could not retrieve any data cannot connect to web server". My internet is working the android system in the box is working. Open elec is not connecting. I have made another bootable sd card same problem. what is your latest update for version 7 I would like to try that. Thanks again
                            What version of OE do you use ? Files video\music from the local network is seen in OE ? He writes OE to output mode, system information, what does it say about a network connection ?
                              Hi No progress here I still have the same situation as in my posts 445 and 447 above. When the start wizard appears it shows my wired connection and after clicking on it the status changes from start to ready. I have taken the box to a friends house and tried to connect using his wifi and password box dumped me back to start screen and no longer saw any wifi networks. After rewriting the Sd card box again saw available networks same result as first attempt. I have tried all dated versions of S95-6.95.3 except the one dated 20160708 this is a ,tar not .img do I simply rename this file to .img . I have also made a bootable Usb drive this gives me exactly the same result as the Sd card. Any assistance with this problem would be greatly appreciated
                                Try to check how they behave these images.
                                Unfortunately I have no models MXQ, so I can't scan and find the error. Perhaps the reason for the different chips of network cards and their settings.
