LibreELEC & OpenELEC for Tronsmart Vega S95
    Originally posted by locki View Post
    balbes150 did you jointed to LibreELEC? Can we looking forward for something?
    Libreelec in the debugging process.
      Meaning we should look forward to LE in future hopefully once debugging process is completed
        During testing armbian found that the main reason is not resistant boot with SD card, tied up with stable performance built-in TV console card reader. I recorded the same image on 4 different maps (class 10). Recorded on the data card, readable on PC, no errors are shown. But when I tried to boot from it on a TV console was out a lot of different errors. Due to the fact that I have to TV the console is connected to the console UART, I was able to observe the processes. As a result, only one card could boot and operate the system. On 3 other maps, even if you managed to load in the process system has got different problems. I began to think that I have a bad card. But decided to check the operation of the card through to the TV connected to the console via a USB card reader. Through the card reader all card earned normally, no crashes, no errors, stable to boot the first time. Moreover, the faster the card is, the harder it is to get to work. Old maps (class 4) the system is more stable. As far as I understand the main problem in the embedded reader, maybe this is a problem only on my instance of TV set-top box. I wrote it for that, would those users that will try to load system with external SD card, when you see the problem is not downloading or not working correctly, be sure to have tried the option boot from USB drives (flash drives and card readers).
          Good Information to know, and appreciate
          SD readers/cards can give you the run around.
            any possibility play there 4K videos? tryed and notworking in 4K play only in full hd // work correctly, i just have stupid switch shich is not able autonegate 100mbit correctly because it is gbit switch grrr on 100mbit line it work nice
              Test image Libreelec (to run from external media). Based on the Libreelec KSZAQ. I just changed the script to boot from external media and added the ability to boot from USB. This image is used download of dtb data from the internal memory.
              Briefly tested on Telos. Like the basic functionality works. Probably will work on other models. Noticed not all buttons on the remote control work.
              For the test I recommend to use a USB stick because they will start more consistently.
                Nice work , I shall give a spin this weekend, is this a stableJarvis or alpha Krypton?
                  Jarvis 16.1
                    I have tested the upgrade from OE ( which is installed in the internal eMMC) on LE . The system is updated and running. Maybe hang at the first start after the upgrade, you need to turn off the power and turn on again. After loading the LE you want to copy to the directory /configfiles configuration file for the remote control (remote.conf). The update file to the internal memory need to take the necessary from the same directory where the files to install to the internal memory.
                    LibreELEC-S905.aarch64-7.0.2.004.tar
                    File for remote control for Telos can be taken here.
                      I have an issue the last week with my Tronsmart S95 Telos. When I start OpenElec from the SDCard, it will not make a connection to my NAS server. I will say in the right upperhand corner it is preparing for the update of the shows and movies.
                      It will stay there fo a while and later when I try to start a movie it says it is no longer available in the library, but it is still on my NAS server.
                      In OpenElec in the System menu, it says the network is connected and I can access the Internet. So that is working.
                      It looks like Kodi cannot find my SMB connection to the NAS server.
                      When I start without SDCard into Android, it has no problem.
                      I already set the OpenElec Kodi startup delay tlo 20 sec. for initializing the network first.
                      Please advise on steps I can take to resolve this issue.
                      Thank you
                        Thanks balbes ...funny I was just going to ask for a .tar
                          Thank you
                          How to set up a network (wire or Wifi) ? If you can see the file in append mode network source ? Files open , if not open with NAS and from another source (e.g. from a PC) ? The music plays over the network ? What is the number of files in a directory ?
                            Thank you
                            hi ihave same problem few days back ... i think problem is tronsmart is only 100Mbit lan devide and you have 1Gbit switch, when you use 100Mbit switch it will be ok, or it can me problem on switch side ... i use tplink gbit stupid switch without management it make same problem wrong autonegotiation speed then it make weird things
                              My whole network is Gigabit (hubs\switches, a few NAS, routers, PC, etc.). All works without problems.
                              Soon I'm leaving for a couple of weeks to places where there is no Internet. So sorry, I will not be able to reply to emails and messages ....
                                I have a Gigabit Network wired. I do not use wifi, only wired.
                                When I go to system, file manager, then to SMB (NAS) connection, go to movies folder share I made there earlier (connection to NAS) it will find and play the movie.
                                When I try to add another source folder and browse to the NAS server (Synology DS214 Play) with SMB it says: Connection Timed Out.....
                                When I try to play a movie from main Kodi screen, movies, go to titles and try from the poster screen it says: the file is no longer available and if I want to remove from librabry....
                                Maybe it is DHCP related and in some situations there is old IP information stored and not refreshed?
