LibreELEC & OpenELEC for Tronsmart Vega S95
Originally posted by ute View PostOh crap ..did a buddys Telos ( Thought I had the telos file ..wrong !! ) and bricked it ...so how do I use the USB burning tool ? and what file do I use ? can I burn OE ? or do I have to go back to android and redo OE
e123enitan Good to hear. balbes150 does very nice work.
Originally posted by minixfreak View Postthanks again the openelec version directly to emmc for the PRO works perfect so far ..... thanks again
Originally posted by balbes150 View PostSpecify which files You used and for what models ? If You are not hard, write more as You have done. This will help other users to properly install OE.
My BOX is META
The steps are simple
1#
I used a free minitool to format my USB, formatted as: File System =FAT32 and Type=Primary (Very Important)
https://www.partitionwizard.com/free...n-manager.html
2#:
I downloaded "OpenELEC-Amlogic.aarch64-Vega_S95-6.95.3-update" for EMMC from https://yadi.sk/d/gZW-PXc7qU4v7/Openelec/eMMC/Telos/20160627,
3#Copy OE in step 2 and saved in USB, Note this file MUST remain unzipped.
4# Powered on META box, I inserted the USB into one of the side USB port, and then followed the USAUL steps to UPDATE.
Then the system reboot into droid ICON with a run process for few seconds, then system shut off and immediately power on into OpenElec Screen>Kodi
The whole process takes less than 2min to complete -was very smooth no hiccup.
Originally posted by balbes150 View PostFor Telos, you need to use these files. File xxxxxx.update.zip - this is for the initial installation of OE to internal memory (eMMC) via the standard Android app "Update&Backup". The file xxxxxxxx.tar is an update to an already installed to the internal memory OE. Specify which files You used ? Write in more detail what steps You performed ?
https://yadi.sk/d/gbqI0Y_xsngKe
Hi balbes
I used this file OpenELEC-Amlogic.aarch64-SPOT_i7-6.95.3-update.zip I think it is the wrong file for the Telos ..( used a SD card and did back up and update from android )anyway I have a black screen ..nothing at all ...waited 10 minutes nothing ..pulled power to reboot ..still nothing
So I am going to use PC and USB burning tool ..can I burn OE at this point or do I need to install android first then back up and update
That is the wrong file for the Telos. Get back to Android first with the USB Burning tool, just takes a minute or so. Then make sure you get the OE file for the Telos. Soon you will be basking in all the OE glory.
The file for the Telos eMMC OpenELEC.. There are two files at the link, you want the zip.
There are currently 1796 users online. 1 members and 1795 guests.
