LibreELEC & OpenELEC for Tronsmart Vega S95
Originally posted by ute View Post
Originally posted by phil766 View Post
Yes pulse audio output was selected.
Originally posted by RISCy Dude View PostWhen you reboot Android(not first start), does the box spend less time on the logo? Do you have USB attached storage when booting, if so, remove it and see if it is quicker. I will compare tonight when I get back to the box.
To the audio issue, I am not sure, as all formats working here. Is there any posibilty you could reburn the card, be very careful in choosing the version for your model. I cannot imagine why it would matter, but if you have a different HDMI cable, give it a try, or a different input on your Sony.
Can you send a screenshot of the audio setting you are seeing in OE?
I timed the boot times, and I need to correct myself. (Re-)booting to android takes about 33 seconds (20 seconds static Tronsmart logo, and 13 animated Tronsmart logo)
Booting to OpenElec from my 8GB class4 micro SD-card takes over a minute (55 seconds static Tronsmart logo, and 13seconds combined for the OE and Kodi boot screens).
I have a much faster SD-card on order to see if it speeds things up.
I'll see if I can get a screen shot tonight. How would I reburn the card without losing my settings/addons? Do I need to copy the backup that you can make inside OE to somewhere?
balbes150 Frist of all thank you for your effort. OE installed on internal memory is great. BT, WIFI (n/ac), HDMI CEC all working great. Only thing I have problem with is connecting external HD to SATA. Is there setting I need to enable like in Official Firmware to be able to mount SATA HDD to Telos? I have Hitachi 2TB drive I'd like to use with Telos and when I connect it to SATA disc is not showing in /dev folder.
Originally posted by minixfreak View Posti have installed your version to the internal memory on the meta and works amazing ... is there an zip i can flash it to the pro version ..... would be greatly appreciated
Originally posted by kemot1000 View Postbalbes150 Frist of all thank you for your effort. OE installed on internal memory is great. BT, WIFI (n/ac), HDMI CEC all working great. Only thing I have problem with is connecting external HD to SATA. Is there setting I need to enable like in Official Firmware to be able to mount SATA HDD to Telos? I have Hitachi 2TB drive I'd like to use with Telos and when I connect it to SATA disc is not showing in /dev folder.
Originally posted by e123enitan View Post@balbes50, could you please direct me the guide for emmc it seem it working nice based on the feedback in this thread, sdcard approach is fine but it lag abit when navigating through movies regards of the type of sdcard that i used given that I have over 2000 movies and 200 Tv shows.
Thankd
2. Copy it to the media with FAT
3. To run the application "Update&Backup" , select the update and to start the process.
What I meant was ....is this an update for OpenElec ...Kodi 17 ?
Same result,
Finding update package.....
Opening update package......
E:failed to mount /udisk (No such file or directory)
I used this file https://yadi.sk/d/gZW-PXc7qU4v7/Open...Telos/20160627
There are currently 1655 users online. 0 members and 1655 guests.
