THanks
LibreELEC & OpenELEC for Tronsmart Vega S95
Hello Doggyofone, His ddBR is for backup and restore of the S95's installed firmware(partitions) and an option to also backup/restore apps and user data to SD card or flash drive. This is done thru a Linux distro, in this case Armbian running from SD card. For info on balbes150's ddBR see post #24 here. Might want to read thru that thread for relative content. I have used it to make a backup on my Meta, but have not attempted a restore from the backup yet. Successful backup and restore has been done by balbes150 on his Telos. It is a work in progress.
Using ddBR means the S95 will not need to be connected to a PC to return to Android, after having installed something like Remix OS, provide ddBR was used to backup Android before flashing Remix OS.
Originally posted by RISCy Dude View PostHello Doggyofone, His ddBR is for backup and restore of the S95's installed firmware(partitions) and an option to also backup/restore apps and user data to SD card or flash drive. This is done thru a Linux distro, in this case Armbian running from SD card. For info on balbes150's ddBR see post #24 here. Might want to read thru that thread for relative content. I have used it to make a backup on my Meta, but have not attempted a restore from the backup yet. Successful backup and restore has been done by balbes150 on his Telos. It is a work in progress.
Using ddBR means the S95 will not need to be connected to a PC to return to Android, after having installed something like Remix OS, provide ddBR was used to backup Android before flashing Remix OS.I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
Ron White
Hi, i have bought this s905 tv box : http://www.geekbuying.com/item/MXQ-P...-0-366249.html can any one tell me if i could dual boot it with openelec ? I cannot find anything related to MXQ PRO+ 4k (2gb ram and 16gb rom) so i am not sure what is different for a 1gb/8gb s905
A couple of quick observation's of OE on the Telos WiFi is quirky on reboot get some crazy IP Addy's with no connection..random sometimes does it sometimes not. Fixed by using a Linksys game adapter hooked to Ethernet port ..perfect no issues now ( run wired in OE settings and shut off wireless option ).
Second really strange on reboot I lose all home screen icons and weather and background art on every reboot ......install again same thing ......strange ( easy fix ...just don't shut off )
Third ... On stock remote you used to press the 3 lines button ,when playing a movie this would bring up the menu bar at bottom of screen ( stop, pause, play, ffwd, rwnd ) now it brings up frame rate info for movie ( fix use a different remote )
Thanks balbes ..for all you have doneLast edited by ute; 06 July 2016, 21:28.
Originally posted by LittleJ View PostHi, i have bought this s905 tv box : http://www.geekbuying.com/item/MXQ-P...-0-366249.html can any one tell me if i could dual boot it with openelec ? I cannot find anything related to MXQ PRO+ 4k (2gb ram and 16gb rom) so i am not sure what is different for a 1gb/8gb s905
To enable multi-boot You can use the universal script. It is suitable for all models. You can use OE on external media (SD card or USB flash drive) from Telos. Just remember to replace the dtb file on your.
There is one limitation. If You want to install OE in the internal memory (eMMC), please specify which option you use. When installed on the internal memory not the correct file, there is a risk to brick.
Originally posted by ute View PostA couple of quick observation's of OE on the Telos WiFi is quirky on reboot get some crazy IP Addy's with no connection..random sometimes does it sometimes not. Fixed by using a Linksys game adapter hooked to Ethernet port ..perfect no issues now ( run wired in OE settings and shut off wireless option ).
Thanks babies ..for all you have done
2 and 3 Describe in detail what you do and what does not work. What version of the system used. I'll try to reproduce it on your device.
Ron White
Originally posted by balbes150 View PostTo use the setting of remote control from his model. 1. Run OE. 2. Open the PC's network environment and to find OE in the list. 3. Access through network directory /storage/config and copy file remote.conf from your TV box. 4. Restart the OE. Either second variant. 1. Install the PC driver ext2fs. 2. Connect media OE to PC. 3. Copy the file remote.conf in the config directory on media with OE.
Do you know how to repair the file so that the enter key works?Attached FilesI believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
Ron White
@ balbes150, Any plan to support Librelec as it appears to catch up with Kodi on Alpha Krypton, while Openelec Jarvis is not finalized, or Could one just update Openlelec with Librelelc tar file and what is implications of doing so?
Thanks for your thoughts.Last edited by e123enitan; 06 July 2016, 19:19.
Originally posted by Doggyofone View Post
balbes150, I found remote.conf via ES File explorer in Android on the MXQ Pro+ box. I copied the remote.conf from the box to a USB drive and deleted the .txt extension that Windows added. Then using Windows Explorer I copied remote.conf from the USB drive into OE configfiles on the SD card. I booted into OE and the remote does most things but the enter key doesn't work.
Originally posted by e123enitan View Post@ balbes150, Any plan to support Librelec as it appears to catch up with Kodi on Alpha Krypton, while Openelec Jarvis is not finalized, or Could one just update Openlelec with Librelelc tar file and what is implications of doing so?
Originally posted by balbes150 View Post1. Perhaps Wi-Fi when you download is not connected due to different time clock (these devices have no built-in clock for storing time). Some of the encryption options is very demanding on the installations hours on devices.
Hi Balbes
Version 6.95.37.0
when you put the add-on icons below the "video" and "program" section on the home page ( and the weather info ) if you reboot the Telos I lose all the icons and have to reinstall ( I do not lose the addon just the icon on the home page )
Second when in a playing movie ( or TV show ) cannot get to the play/stop buttons at bottom of screen ( should have to press the middle button on bottom of remote to pull this menu up ) but what it does now is show frame rate info of the movie
With the wifi I even had OE wait 30 sec before starting ..(wait for connection) still random on when it gets a good connection , some times it works sometimes it does not
There are currently 2057 users online. 0 members and 2057 guests.
