The menu item "Reboot in NAND" does not work with my version of multi-boot (using the file s905_autoscript). In the near future I plan to add this feature in my script. If you can, make please a screenshot on your Meta, with a window that displays the system load (as did trebor in the topic i7)
LibreELEC & OpenELEC for Tronsmart Vega S95
The renewal of the image. Added support for restarting the system from the internal memory (menu item "Reboot in NAND"). The paragraph now correctly works with external media. Added in - test support the dtb file from the platform p201 (system based on NAND). For those who have such equipment, please check how would work this way. In the image on a FAT partition, added the files (aml_autoscript aml_autoscript.zip) to activate multi-boot mode "Update&Restore" from the regular firmware Android.
Originally posted by balbes150 View PostThe renewal of the image. Added support for restarting the system from the internal memory (menu item "Reboot in NAND"). The paragraph now correctly works with external media. Added in - test support the dtb file from the platform p201 (system based on NAND). For those who have such equipment, please check how would work this way. In the image on a FAT partition, added the files (aml_autoscript aml_autoscript.zip) to activate multi-boot mode "Update&Restore" from the regular firmware Android.
https://yadi.sk/d/Tnbwje1JubcxR
This image to external media (SD card and USB flash drive). Image for installing to internal memory is not yet ready for use. The files to install to the internal memory is, but when you try to install to the internal memory , at startup I receive an error that the file system on disk /dev/data is corrupt and the boot process stops. I'm trying to figure out why. Likely to have been changes in source code when migrating from version 004 to version 006. These modifications inhibit the normal operation of the system on models with eMMC memory. About the same write error many users on the forum LE. Perhaps the reason for the updated version of check disk or its settings.
Originally posted by balbes150 View PostThis image to external media (SD card and USB flash drive). Image for installing to internal memory is not yet ready for use. The files to install to the internal memory is, but when you try to install to the internal memory , at startup I receive an error that the file system on disk /dev/data is corrupt and the boot process stops. I'm trying to figure out why. Likely to have been changes in source code when migrating from version 004 to version 006. These modifications inhibit the normal operation of the system on models with eMMC memory. About the same write error many users on the forum LE. Perhaps the reason for the updated version of check disk or its settings.
Cheers!Last edited by e123enitan; 31 August 2016, 19:46.
You can check these options
1. to try to run LE without replacing the dtb file (use the one that is in the image)
2. if the system does not work, replace the dtb file to the one that is in the current firmware of
3. if it doesn't work with dtb file from the firmware, in turn, try all files in this directory
4. if none of the options does not work, then we need to collect personal dtb file from source
So in this case if I can get a copy of a dtb for a Meta I should be able to load you LE on this box.
I would appreciate a copy of the dtb from anyone who might be willing to post/pm me a copy.I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
Ron White
The data dtb.img for the new kernel Libreelec, for model Telos Meta Pro are in the dtb.img file which is included in the composition of the image. You need to initially try to boot without modifying the file dtb.img. If that doesn't work then try the files from KSZAQ from consoles with similar parameters.
Originally posted by balbes150 View PostThe data dtb.img for the new kernel Libreelec, for model Telos Meta Pro are in the dtb.img file which is included in the composition of the image. You need to initially try to boot without modifying the file dtb.img. If that doesn't work then try the files from KSZAQ from consoles with similar parameters.
Well I've tried on two different working SD cards and a good USB stick and all I get is a blank screen.
I'm not sure dtb's kszaq has listed would be close to what I have. I'm surprised that the Meta Pro dtb doesn't work. Your 6.95.3 works really well on this box. I tried the dtb from that img and got a blank screen.
After all that I put in my original 6.95.3 sd card in with your image and OE boots right up.
Its a mystery.Last edited by Doggyofone; 02 September 2016, 01:39.I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
Ron White
Originally posted by balbes150 View PostWhich files have You copied on the card with OE ? Which file system start ? The problem with the new image LE (006) that now uses a new kernel with a different algorithm use the dtb data. For new kernel you need to use the new dtb file (which added and changed data).
When these attempts didn't work I tried the dtb.img from your OE 6.95.3 which did not work. When I put the 6.93.3 sd card back in OE loaded no problem.
kszaq's instructions are to download a dtb from a list of available dtb.img for different boxes. There are no vega dtb available.I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
Ron White
There are currently 3060 users online. 0 members and 3060 guests.
