R-BOX Android 5.1.1 RK3229 2/8GB KODI 16.1 4K 10/100M LAN Bluetooth4.0 WiFi HDMI DLNA - Silver/ Black
Other than the reboots when using Eth to stream via Kodi(Trebor does not have them), this box is inline with my expectations.
Just checked WirelessUpdate app, an update dated 2016-06-15 popped up, getting ready to apply it now.
Changes show...
1.) updated Kodi add-ons. Don't care, I don't use the installed Kodi.
2.) fix remote bug. I am unfamiliar with this bug.
I want unified storage and my Eth when streaming via Kodi resolved(if possible).
This is by far, the worst box I have purchased in a while. It is in need of serious work on the firmware. Even your ZDMC won't passthrough Dolby, much less HD audio. I will play with it for another day or two, then maybe spill coffee on it.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostThis is by far, the worst box I have purchased in a while. It is in need of serious work on the firmware. Even your ZDMC won't passthrough Dolby, much less HD audio. I will play with it for another day or two, then maybe spill coffee on it.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
scooter2014 Yes, I have tried SPMC, results were negative.
I see no parameter file in the OTA., would this need to be added. I am familiar with RK stuff, but this box looks a bit different. For instance, what is trust.img?
clarkss12 To confirm our boxes ARE the same, does your build.prop look like this? FT would not let me attach build.prop, so I added".zip" to it, just rename it to build.prop and open with wordpad or other text editor.
Here is the latest OTA.
If yo have trouble using the WirelessUpdate app, rename OTA.zip to update.zip and copy to card or flash drive. Reboot box and it will tell you it found an update, and ask you if you want to apply it. Click yes. It should spend a second checking the file and then reboot to the little green droid with the spinning gear.
Hope it improves your experience clarkss12.
There are currently 2456 users online. 4 members and 2452 guests.
