YUNDOO RK3399 Y8 TV Box - 4GB RAM + 32GB ROM
3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
michael2t
1. search here (OsitKP MX Player, needs registration)
(not "Pro", only "Free" example: MX_Player_1.9.20_Lite.apk ( 11,54 МБ)
MX Player 1.9.16
MX Player 1.9.17
MX Player 1.9.20
MX Player 1.9.21
MX Player 1.9.22
MX Player 1.10.7.1
MX Player 1.10.8.1 (latest stable version)
2. test file: Motion_1080p 23.976 (check for twitching in the middle line; should play smoothly, without a single jerk). display frequency - 50 Hz (possibly 60 Hz (?)), "progressive".Last edited by BidonX99; 10 December 2018, 18:49.Yundoo Y8 A6 [RK3399]
MX Player 1.9.16 - 1.10.8.1 (rar)
LPCM only, OS A6 (A7?), Sound Devices: "Default" (do not turn on "SPDIF" и "Bitstream").Yundoo Y8 A6 [RK3399]
Thanks For the Link Post for the Free MX Player ...
1.9.16 was labeled DTS ...do they all have the DTS Patch ?
Do All version support DTS and AC3 ?
So Which Version did You find to be the best ?
And Which One do you use on a Every Day Basis ?
Thanks again for the Post ..
Michael T.Last edited by michael2t; 16 November 2018, 19:40.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
Hello BidonX99
I was hoping to Find one with Audio normalization? For MX player ... I know there is one for Kodi
Or A Audio normalization Patch ?
Do You know of anyone doing this patch ?
Thanks again
Michael T.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
OsitKP has all versions with DTS + AC3 codec (patched) - Free & Pro.
But I play files only Hi10P, stereo PCM 24-bit (FLAC),
with a modified files for better sound (OS A6):
1. audio_policy.conf:audio_hw_modules {
primary {
outputs {
primary {
sampling_rates 192000
channel_masks AUDIO_CHANNEL_OUT_STEREO
formats AUDIO_FORMAT_PCM_32_BIT
devices AUDIO_DEVICE_OUT_EARPIECE|AUDIO_DEVICE_OUT_SPEAKER |AUDIO_DEVICE_OUT_WIRED_HEADSET|AUDIO_DEVICE_OUT_W IRED_HEADPHONE|AUDIO_DEVICE_OUT_ALL_SCO|AUDIO_DEVI CE_OUT_AUX_DIGITAL|AUDIO_DEVICE_OUT_SPDIF
flags AUDIO_OUTPUT_FLAG_PRIMARY
spdif_passthrough {
sampling_rates 44100|48000
formats AUDIO_FORMAT_PCM_16_BIT
devices AUDIO_DEVICE_OUT_SPDIF
flags AUDIO_OUTPUT_FLAG_DIRECT
hdmi {
channel_masks AUDIO_CHANNEL_OUT_5POINT1|AUDIO_CHANNEL_OUT_STEREO |AUDIO_CHANNEL_OUT_7POINT1
devices AUDIO_DEVICE_OUT_AUX_DIGITAL
2. build.prop:af.resampler.quality=255
af.resample=192000
ro.audio.samplerate=192000
persist.dev.pm.dyn_samplingrate=1
persist.audio.samplerate=192000
persist.audio.pcm.samplerate=192000
persist.af.resampler.quality=255
persist.af.resample=192000
192000 (192 kHz) can also be replaced by 48000 (48 kHz).
With multichannel sound, the smoothness of a 23.9 Hz video on a 50/60 Hz screen may be disturbed (?).Yundoo Y8 A6 [RK3399]
Originally posted by mo123 View PostI play h264 Hi10P L5.1 on RK3229/RK3328 in Kodi 18 and it plays great with new firmware from May.
CPU usage even 30% hardware decoded.
All these videos can play - https://www.koi-sama.net/files/hi10/
MXPlayer, RKMC can still only play L5.0
Problem was not in profile L5.1, but in ReFrames (inflated non-standard values).
Plays in HW (YUNDOO Y8):
Format profile : High 10@L5.1 - OK
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Format profile : High [email protected] - OK
Format settings, ReFrames : 4 frames (standard Blu-ray Disc)
Will not play (HW):
Format profile : High 10@L5.0 - Bug
Format settings, ReFrames : 16 frames
Format profile : High [email protected] - Bug
Format settings, ReFrames : 15 framesLast edited by BidonX99; 20 April 2019, 21:34.Yundoo Y8 A6 [RK3399]
Originally posted by mo123You do have sample videos for last 2 bugs?
Format settings, ReFrames : 16 frames:
[neko-raws] Nanatsu no Taizai - Imashime no Fukkatsu - 21 [BD][1080p][FLAC]
2) Format profile : High [email protected] - Bug
Format settings, ReFrames : 15 frames:[Coalgirls] Sword_Art_Online
HW only in MXPlayer, RKMC/FTMC.
p.s. ReFrames 16 needed for a stream of 300 000 Kbps, but not for 8 000 - 40 000 Kbps. Problem in releasers.Last edited by BidonX99; 23 April 2019, 18:27.Yundoo Y8 A6 [RK3399]
Please provide a logcat if you can for playing the 2 videos with
1. MediaCenter app
2. Kodi 18
3. MXPlayer
restart the device after each log.
Use adb to get logcats or install Catlog or Syslog apps if rooted to get the logs.
I will also try to test on RK3229, RK3328 devices.
Originally posted by mo123 View PostCan't any app still get the logcat?
The problem is 16 ReFrames - first of all in the illiterate video release. and RK codecs
Originally posted by BidonX99 View PostNo logcat in my firmware. I cut out all Google & app/hw logging to free up resources and extend the life of NAND-ROM.
You need a very specific firmware to play 10-bit H264 correctly.
I saw on Nougat RK3399
720p 10-bit H264 doesn't have a problem but it's because it's software decoded and CPU is fast enough to do it.
1080p 10-bit H264 is too heavy for software decoding.
You will need to test some Oreo or Pie firmware with better 10-bit H264 hardware accelerated support, but very few manufacturers released it, they stick to Nougat only.
Hopefully I can get a Khadas Edge RK3399 with Android Pie firmware soon then I can test 10-bit H264 better.
Originally posted by mo123 View Postfor software decoding.
test file to check jerking: Motion_1080p 23.976
Originally posted by mo123 View PostKhadas Edge RK3399 with Android Pie firmware soon then I can test 10-bit H264 better.
Although I doubt that it will playing.
There are currently 2184 users online. 0 members and 2184 guests.
