Yundoo Y8 4GB/32GB - SCV1-Beta
YUNDOO RK3399 Y8 TV Box - 4GB RAM + 32GB ROM
Hello
I have a big problem with yudoo y8. When I press the button nothing happens.
No LED lights and the box does not start. This happened on the second day after
the first use. I did not make any manipulation on the box. I fear that it is the
circuit of power that has broken down.
If you think this is the case then how to fix that.
Thank you in advance for your help.
sarah
sarah
I wouldn't say so that customer are muted or moaning...
There are a lot, A LOT of firmware problems:
1) jittery video on almost all video players
2) big hd-rips are really problem for this box by the air - yundoo y8 + linksys ea9500, 10 feets far from router.
Any video player can't satisfy acceptable transfer rate and stops for re-buffering next portion.
3) YouTube app is completely dead
4) weird Google Chrome with overlapping toolbar
and so on and so on.
Gonna flashing my Y8 with custom ROM of superceleron and hoping for miracle.Last edited by parseval; 15 May 2017, 21:32.
Originally posted by scooter2014 View PostCheck to see if bullet type wifi. Maybe poorly placed or hittin board. But worth a check to see...
tv-box is undamaged and there is no any scratches or cracks. So for now I wont to open it.
Originally posted by parseval View Post
Not sure I correctly understood what 'bullet type wifi' means. It is wifi ac 5ghz network which is used for connection by Y8. Small hd-rips are good. But 10-20 gigs(and more) rips always stops and re-buffering.
There are currently 1139 users online. 0 members and 1139 guests.
