YUNDOO RK3399 Y8 TV Box - 4GB RAM + 32GB ROM
@Johndoff.
You wouldn't be so much impressed if you had compared RK3399 to RK3288. RTD1295 is similar to RK3368.
My RK3288 device can do about 63000 points in Antutu 6.2.7. That's why RK3399 TV Box especially with current price (144$+) aren't interesting for me.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
@Johndoff.
My current hardware is as in my post signature:
Beelink R89 v3.0 2/16GB with Wasser's 4.0.11 ROM; OC'ed CPU: 1920MHz @ 1.425V, GPU: 600MHz @ 1.25V, RAM: 792 MHz @ 1.2V
It was released more than two years ago (mid 2015).
40000 Antutu points for RK3288 SoC that was in KitKat times with Antutu 5.x version. What's more most of the ROM's had kernel which limited CPU frequency to 1.6GHz even when reporting 1.8GHz or even 2GHz. Not fair.
Some of cheaper devices have poor RAM modules which can bearly work with 533Mhz (1066MHz DDR) memory clock. Mine don't have that problem and I can set memory to higher specs than RockChip even recommend for RK3288 SoC: 800MHz = 1600MHz DDR. Which is similar to what RK3399 is capable.
You can check more recent tests of RK3288 SoC with Antutu there: http://freaktab.com/forum/tv-player-support/rk3288-devices/beelink-3288-devices/609188-wasser-marshmallow-rom-sdcard-version-r89-2g-16g?p=609599#post609599RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Johndoff View PostInteresting, it seems your model is no longer an original R89, but works better than before? And could you tell me if the original R89 support android Marshmallow?.
Thanks to Wasser this device is quite usable with Android Lollipop and recent security updates. Maybe not so recent because they are from October last year.
Does anyone have any thoughts on installing the Ubuntu Linux or even the dual boot Android/Linux firmware from the Firefly RK3399 Development board.
The only difference i think i had found was the Ethernet port, being a Realtek RTL8211E on the Firefly and all the other addon interfaces the firefly has.
i think It would be insteresting to see if this works,
im happy to try it as long as we can get our hands on the original Y8 firmware for recovery reasons
I have ordered my Y8, should be here in max 3 weeks.
There are currently 3499 users online. 1 members and 3498 guests.
