I choose upgrade option on batch tool. It took about 15 min to load but everything works smooth now
K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Originally posted by fredphoesh View PostHi there,
Are you using lewy's 1.20 rom?
I find wassers 1.2.5 is way too unstable to use.
tx
Mark.
I have some 720p kernels i want to check their stability.
One of the things I miss about Wassers v1.25 rom is the power menu/system... when I press the power button on my wireless USB keyboard, the C918 goes off, and when i press the power button on the device again, it comes to life. On this lewy's 3.2, when the device powers up again, there is no keyboard...
Code:echo "freezer" > /sys/power/pm_test
Device : CS918 --> Sony Bravia 32" 720p
Naaah.. my English are good... most likely your eyes are broken o.O
hi.
I used 3.2 fimware Lewy. I installed k-r42 wasser firmawe based on 4.4 kitkat. Device does not start. I installed 3.2 again but it's fail. I use RKDevelopTool_v1.37 and want install firmware-wasser-1.2.5. After eraseIDB , pc dont see device.... i can't install anything.... when i turn device, light goes out after a few seconds..please help!!!
ps.sorry for my english. I hope everything is understandable
install kitkat again, it will work.
or manualy flash loader from 4.2.2 firmware using finless tools.Everything is possible if we work together!
try holding power button while flashing the device, if that dont work google mask rom mode.Everything is possible if we work together!
sure, glad i could helpEverything is possible if we work together!
Originally posted by psychorat View PostNo im using 3.2 but im looking for a good kernel because stock 3.2 720p gives reboots.
I dont know if applied in 3.2's init.d but did you tried this script suggested by Gormar? It seems to help in some power problems.
Thanks for the response
I have never run a script like that, don't know how... so nope_________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
Hey Lewy,
do you know if any of the roms you made will work with TuneIn on an ethernet - ie, will it ask me to connect with a wifi/data like it does on the 1.2 rom?
Thanks!
Mark._________________________________________
I'm sorry if this has been asked and answered already. I couldn't find eny information on that.
It's a good thing that there are 3d party firmwares for this device. There is no guide on how to identify the proper revision, what is th difference between revisions, how's the flashing pricess to be done, how to choose the correct ROM, what will happen if you flash wrong ROM (given that there are so many versions of the device).
A guide with most important information would be great.
For example in my case, I have the device for a week now. There are no stickers, not any model numbers, revisions, etc. I can't find a way to open the case to make a picture of the PCB. So, I guess I'm stuck. How do I find the proper version ?
Thank you all.
Originally posted by kamelot View PostI can't find a way to open the case to make a picture of the PCB
There are currently 1603 users online. 0 members and 1603 guests.
