K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Originally posted by turbolooser View Postso you flashed boot.img + kernel.img from wasser 1.2.4 new rev after flashing HFW 3.2 beta?
what cpu clock do you have now? would the oc kernels work with that setup also?
ethernet and wifi working without packet loss?
thanks for any feedback
With wasser new rev kernel it is limited to 1.4Ghz even with oc kernels, I think that there is a cpu table problem in this new revision kernel.
Ethernet works fine (I do not use wifi) but I did not check if there was packet lost. I'll be able to have a look next week as I am currently "out of home" in Berlin.
Franckfor windows8.1 drivers fix follow this.
Jesurun v2.1 old rev with wasser firmware 1.2.5
K-R42 v2.1 new rev with wasser firmware 1.2.5
Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
Minix neo s8s with stock firmware
Plex streamer with external MX player
TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
Originally posted by QuAn64m View Posthow can i extract the system.img of the HFW_3.2F.img somehow i cannot open it. neither with daemon tools or 7z or winrar ... ?! can you help me ?
You need to use wendal tool : RK3066_IMG_Mod_Tool
http://www.rockchipfirmware.com/developer-tools
Originally posted by STOO View Poston my kr-42 with hfw 3.2,i flashed wassers oc kernel 1800,from miscellaneous in settings.
Had to download with chrome though.all working great.
STOO
Do you have old or new revision board ?
Originally posted by franckleroy View PostYou need to use wendal tool : RK3066_IMG_Mod_Tool
Franck
Originally posted by STOO View Postmine is old revision[pretty sure?]??????29
With new revision and wasser kernels I didnt find a way to have more than max at 1,4Ghz
Franck.for windows8.1 drivers fix follow this.
power scripts
Just my contribution:
A script which tells you if your device is asleep (because SSHdroid works even in sleep mode):
Code:#!/system/bin/sh HODNOTA=`cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq` if [ "$HODNOTA" == "816000" ]; then echo "Sleeping" else if [ "$HODNOTA" == "1608000" ]; then echo "Awake" else echo "Unknown: $HODNOTA" fi fi
Code:#!/system/bin/sh if [ "`cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq`" == "1608000" ]; then su -c sync su -c input keyevent 26 echo "Sleeped" else echo "Not awake" fi
Code:#!/system/bin/sh if [ "`cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq`" == "816000" ]; then su -c sync su -c input keyevent 26 echo "Waked" else echo "Not asleep" fi
Just XBMC v4 apk problem with HFW v3.2
I just switched from Wasser firmware 1.2.4 to Lewy HFW v3.2 firmware (due to no optical pass through in Wasser) and have found that the Add Ons / Programs dialogue in JustXBMCv4.apk crashes out of XMBC every time. I've been trying to add some Android apps such as MX Player and cannot do so because of this problem. I'm using an old revision K-R42, no custom kernel. Anyone else experienced this? Does anyone know a fix? JustXBMCv4.apk did not crash in this way in any other firmware I have loaded, just Lewy HFW v3.2.
Hello my K-r42 Box act strange while playing or to pause a movie the xbmc crash in the launcher. i made a logcat to see there is a problem with the mediacodec. here is the logcat please help me.
can it be there is a problem whit my kernel? i use kernel_1080p-k_r42-revision_2.1-111113.
i hat a k-r42 box new rev
hfw 3.2 with the 1080p kernel from Wasser and the actuelle nightly build Xbmc 13 alpha 12
Thanks a lot for helping and sorry for my bad englisch
About K-R42 rotation problem
Hi everybody,
I'm new here and my device too.
I would like to help me about my problems:
1. How to bring up System try visible again?
2. I don't know how, but when I restarted my K-R42, next boot was 180 degree rotated display. How to rotate display to normal? I set HDMI port to 1080p 60Hz.
Please, help me!
My K-R42 is without Bluetooth. Of course, I tried to enable it . Is this possible to cause my problems?
Best regards and thanks a lot
Remote key mapping in BeyondXBMC / SPMC
On HFW 1.2.0 firmware BeyondXBMC and SPMC "think" that OK button on stock remote is Menu. According to BeyondXBMC author on latest firmware from wasser all remote keys work just fine. Any idea on how this can be fixed?
I tried looking for key press events in XBMC log file, but it looks like our remote is not generating any...
Lewy, concerning above he says his ok button doesn't work but it in fact triggers menu and menu key does nothing for him. I use a k-r42 myself with Wassers older rom which I have had on there a while and the stock remote works fine for me.
It's probably just a kl file.To Infinity and Beyond.... XBMC
Originally posted by MikelThief View PostCan you provide RKxx remote kl file?
Wysłane z mojego iPhone 5 przez Tapatalk Professional
Code:#$_FOR_ROCKCHIP_RBOX_$#$_rbox_$_modify_$_chenzhi_20120220: add for IR remote key 28 ENTER key 116 POWER WAKE key 158 BACK key 139 MENU key 217 SEARCH key 232 DPAD_CENTER key 108 DPAD_DOWN key 103 DPAD_UP key 102 HOME key 105 DPAD_LEFT key 106 DPAD_RIGHT key 115 VOLUME_UP key 114 VOLUME_DOWN key 143 NOTIFICATION WAKE key 113 VOLUME_MUTE key 399 MEDIA_PLAY_PAUSE key 64 MEDIA_PLAY key 65 MEDIA_PAUSE key 398 MEDIA_STOP key 501 MEDIA_REWIND key 500 MEDIA_FAST_FORWARD key 412 MEDIA_PREVIOUS key 407 MEDIA_NEXT key 2 1 key 3 2 key 4 3 key 5 4 key 6 5 key 7 6 key 8 7 key 9 8 key 10 9 key 11 0 key 111 DEL key 58 SPACE key 400 EXPLORER key 195 BUTTON_8 key 194 BUTTON_7 key 193 BUTTON_6 key 388 TV_KEYMOUSE_MODE_SWITCH key 420 TV_MEDIA_MULT_BACKWARD key 421 TV_MEDIA_MULT_FORWARD
There are currently 5108 users online. 1 members and 5107 guests.
