Did you use the "Upgrade" or "Restore" option when you flashed this firmware ?
K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
Originally posted by rjtm View Posthttp://www.hindotech.com/download/
This version is much better then I tried before on CS918 NObt, everything works fine, including power on/off, resolution and smooth UI.
PS:first time reboot if nothing output from HDMI, you should use composite video and goto setup to change screen scale(max. or min.) and reboot.
Has anyone tried this firmware?
Is it rooted version, or not?
Originally posted by rjtm View PostThis is a rooted version, but a little different from other rooted method. After you restore this firmware, the system is totally rooted, no supersu or superuser at all.
And is the Skype working on it properly. I mean Skype does not support rooted version so far I know...
I had this issue on lewy's rom, but otherwise his rom with up to 1,8 GHz processor speed is great...
Have you compared the lewy`s rom with you have flashed just recently?
What is the difference in restoring or upgrading the rom?
Originally posted by alexandroff View PostAnd is the Skype working on it properly. I mean Skype does not support rooted version so far I know...
Sorry! I didn't know the difference between these two methods, too.
Originally posted by rjtm View PostI did not use skype on CS918. (But my tablet z is also rooted, and the skype works fine). In my case, lewy's 1.8G is not stable on my box, it crashed sometimes, and when I use wireless mouse it lagged a lot. After this version, mouse cursor no more laggy again.
Hi!
Could you download and install the Skype on your device and check if the voic calls work proprely on it?
By the way, I did download and install skype on cs918, and it can run and login.
Originally posted by rjtm View PostAre you sure your box is CS918?? Because my cs918 didn't have mic or line-in, how can I test "voice call" for you?
Yes, I have the CS918.
There is USB port and AV out to connect a webcam with microphone to it.
I can also login to Skype, but unable to make video calls, as Skype immediately after making a call restarts.
Can you connect a webcam to your device and try it out?
Originally posted by Ateakian View PostI am having the same issue with this and all of lewy20041's roms currently. Im using a logitech c920. Skype used to work great. Maybe it is something in the skype apk?
I'm using a T-R42 with my logitech c270... skype works, although video doesn't seem to work for me.
Bill
Originally posted by bill-ns View Post
Skype 3.2
Download Link for skype 3.2
I use the inverted version beta from this site and it works well ...
http://forum.xda-developers.com/show...php?p=43288187
Google is your friend
Michael T.
from where can I download this firmware v3.2?
Is it compatible with CS918 without Bluetooth?Last edited by michael2t; 12 December 2013, 13:18.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
There are currently 2242 users online. 0 members and 2242 guests.
