i will fix it today.
K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
maby i packed something wrong.
i will fix it today.Everything is possible if we work together!
wasser i just saw that your kernels newer or older arent fuly compatible with my new firmware.
some apps (many) wont install.
its due to kernel dont create device-mapper under /dev/ directory
i will try to find a work around but if you can look into the kernel it will be nice to
dm_mod.ko i dont know if this can be compiled as a kernel module or it need to be in kernel
itself. on stock kernel its present and working ok.
so sorry but no new firmware until this i solved.Last edited by lewy20041; 10 September 2013, 11:13.Everything is possible if we work together!
Originally posted by wasser View Postyou can flash it with ROM_Flash_Tool_137 under windows, or use rkflashtool to flash it under linuxexample unter linux: rkflashtool w 0x00004000 0x00008000 < kernel.img
Originally posted by lewy20041 View Postwasser i just saw that your kernels newer or older arent fuly compatible with my new firmware.
thanks
waiting thanEverything is possible if we work together!
Good waser
Originally posted by lewy20041 View Postthanks
waiting than
i will try them out and post backEverything is possible if we work together!
it look ok now.
v2.0 720p fitmware ready for download.
i need some testers.
please post feedback as its important.
download:
http://d-h.st/tvCEverything is possible if we work together!
download:
http://d-h.st/tvC
Fine ! I'll test it tonite. It does include last wasser kernel ?
Franck.for windows8.1 drivers fix follow this.
Jesurun v2.1 old rev with wasser firmware 1.2.5
K-R42 v2.1 new rev with wasser firmware 1.2.5
Minix neo x7 mini with quickshot firmware 3.1 with kernel HDMI patch
Minix neo s8s with stock firmware
Plex streamer with external MX player
TV Sony Bravia HDMI 1080p/60hz with AC3/DTS passthru.
Originally posted by lewy20041 View Postplease post feedback as its important.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
i disabled the mass storage for now.
i will enable it later in proper update.
thanx for feedback, waiting for more.Everything is possible if we work together!
download:
http://d-h.st/tvC
You devs. are ****IN GOOD
After the second flash on my cs918 (jesurun, k-r42) everything started fast and fine.
I set the sound output SPDIF throughput or what, and the 5.1 worked great! It's exactly 5.1!
But no work with dts.It's just stereo for me.
I used a Logitech mouse 'cause my IR not react or anything. Am i must use or set something in the mapper app to use my IR?
I've got this type of remote control (http://image.arukereso.hu/full/20207...918-fekete.jpg)
So, my first observations the most and tried things worked perfect.
-wireless mouse
-SPDIF (optical) 5.1
-WiFi with internet
There are currently 1598 users online. 0 members and 1598 guests.
