K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
by params i mean sdcard/flash swiched in vold.fstabEverything is possible if we work together!
Originally posted by lewy20041 View Postby params i mean sdcard/flash swiched in vold.fstabk-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
rom 1.0.4 (kitkat) old revision Wasser
cant say much,
i have 3d tv and side by side and over/under movies ar working ok.
you probably think about bluerey isos right.
are there any 3d player app?Everything is possible if we work together!
That's what I wanted to know , just that I do not have 3d tv, but this month I plan to buy it on this and askedk-r42 Board TN-BX09_V.2.1 2013/05/31 ,wifi RTL8188ETV,
little problem
First of all, great job, i have read all this thread and i am amaized...
I want to connect my CS-918 Android TV Box to my Pc.
I have Win 7 64Bit.
I download the Rockusb_v3.5 drivers, in the device i set the USB Debug mode,
When i connect the USB cable, In the Windows Device Maneger it recognize as CS918.
I tryed anather cable and the same....
Then i click 'Update Driver' select the path of the 'Rockusb' but it does not installing it.
Over 2 day that i try to search for driver and nothing...
I have attached pic... Please help me
Originally posted by eli200601 View PostFirst of all, great job, i have read all this thread and i am amaized...
I have Win 7 64Bit.
After you choose "Update driver software", click the "Let me pick from a list of devices" button and then click the "Have disk" button to manually select the 64bit driver file. Choose "Install anyway" if you get a warning message.Device : CS918 --> Sony Bravia 32" 720p
Naaah.. my English are good... most likely your eyes are broken o.O
problems with 1.2.2
Hi, I have installed 1.2.2 and I had no HDMI sound. Reboot didn't help. Stock firmware was OK.
After installing latest Wesser kernel, I got sound from AV-out but still not from HDMI. In XBMC, GUI sound lags as hell. Video playing sound is OK and in sync.
Also, I don't get the shutdown menu anymore (It worked before, I tried downgrading do 1.2.0 and then upgrading back to 1.2.2). If I press the button long or short, the display goes "no signal" and the device isn't responding for some time, then it turns on again (couple of minutes).
Finally, I have 1080p Avengers, which lag in XBMC. I need the 1080p to work flawlessly, how can I debug this?
Today v2.0.1
I will need some testers again.Everything is possible if we work together!
here.
i will post link later.
change log will folow.
i will need somebody to post if dts is working as i pached the library but im mising 1 ofset so its may work or may not:"Everything is possible if we work together!
its uploading.
just few more minutes.Everything is possible if we work together!
v2.0.1
http://d-h.st/6mO
Please test and post back your findings.
What i want to know the most:
-is it stable for you
-on what device are you using it (k-r42, jesurun, cs918, ugoos ut1)
-do dts and dolby passtrought work for you
-do movies stater for you
Feedback is important to make this rom better
Regards
lewy20041Everything is possible if we work together!
Originally posted by lewy20041 View Postv2.0.1
http://d-h.st/6mO
I will try another cable & computer
ah, passed 1st time on another computer... will report findings in a while..._________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
There are currently 1432 users online. 3 members and 1429 guests.
