I just registered to send my big thanks to all the developers, and also the people reporting bugs thus helping remediation of all issues.
I bought something differently named, but exactly same hardware from Pandawill, HI718. It is black and has the same remote as pictured some comment ago. Installed 1.2.2 1080p firmware, and it is working nicely for me, I have no unexpected reboots so far, I was able to complete Antutu (3.x and also the new 4.something). XBMC also runs okay (downloaded one from xbmchub.com), I am playing back files from my Windows HTPC via standard Windows SMB share.
My Logitech MK250 Keyboard and mouse works fine, it just not hide the soft keyboard when I am using it. Original remote works partially, as I am no longer able to turn on mouse mode
I also have a RC11 airmouse-keyboard combo which has a tendency to switch off mouse mode, but that is unrelated as it does the same on my PC too.
Both wired and wireless ethernet works too. I found a funny issue with Play Store when you set update only on Wifi it literally means it, so it does not do anything on wired however that supposed to be free too, but it indefinitely waited for connection until I realized that.
Only thing that bothered me with these Android sticks and boxes (this is my 3rd so far) that shutdown does not seems to work, it simply reboots its. I assume developers already working on it and I am not worrying
My plan is to use it as a terminal client for my HTPC (2x Client works nicely, but mouse cursor is enormous in android), so I can replace the old Dell D600 that I am typing on now, and occasionally use it as a mediaplayer. Web browsing works, but I still feel that it is faster via a terminal than in any browser I've tried so far.
I also downloaded the latest Wasser kernels, but haven't had time yet to try those.
Keep up the good work, I really appreciate your enthusiasm and excellence!
Edit:
I have not seen any screen issues so far (no weird pixels etc). Using the original cable with a female-female extender to a standard HDMI cable to my fullHD Philips TV, plus used the same method to my monitor via hdmi-DVI cable and 720p only. HDMI Audio also worked on the TV, sadly my monitor is not HDMI sound compatible (ordered a new one, will get it next week)
