Sent from my Nexus 4 using Tapatalk 2
K-R42 Hybrid Firmware (HFW) 1.1.0 by lewy20041
flashed the new 1080p kernel but output is still not so great. runs great just img has lines jumping all over. setting it to 720 lines are gone but micro sprites can be seen at random when close to screen.
img of 1080p out with lines http://db.tt/Ojl9VHRn
i can also capture video direct from hdmi in 1080p if this will help.
Keep up the great work guys
try difrent hdmi cableEverything is possible if we work together!
did and results are the same. also tryed running through my hdmj capture card and see the same lines. Dont have another hdtv to test but same img on capture card leaves me to think some bug in kernel.
v1.2.0 final 1080p rom is just fine...idk
have you tested most current wasser kernel on 108p tv?
yap tested them and dont see this lines.
im not using stock hdmi cable.
framework 1.2.2 have wasser kernels but not the latest one.
also do not flash wasser kernels to 1.2.0 you will get reboots.
be sure to use it with 1.2.2Everything is possible if we work together!
bt should be working but be sure to make a backup of kernel as i dont see stock t-r42 firmware:"Everything is possible if we work together!
Originally posted by Tech View Postflashed the new 1080p kernel but output is still not so great. runs great just img has lines jumping all over. setting it to 720 lines are gone but micro sprites can be seen at random when close to screen.
ROM 1.2.2 with default 1080p kernel.
Stock HDMI cable.
The problems are only in 1080P 50/60 HDMI mode.
In 720p HDMI mode they aren't any problems with the picture.
ROM 1.2.0 1080p works fine.
I didin't try new kernles to 1.2.2 ROM.
Hello All,
My K-R42 has just arrived from geekbuying. It took 14 days to arrive - I cant wait to finish work and set it up.
Should I flash lewy stable or the beta then flash the latest wazzer kernel?
Thanks to lewy and everyone that is actively developing for this device.DEVICE: K-r42 from geekbuying
OUT: 50 inch lg plasma and 42 inch lg lcd.
IN: droidmote
SDK2 rom now in the makeingEverything is possible if we work together!
Hey Great
Originally posted by lewy20041 View PostSDK2 rom now in the makeing
What are You going to Call it 1.2.3. ???
How about a Change Log ... So We can See all of Your Goodness at work ...(((SMILES)))
Michael T.3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
There are currently 2871 users online. 5 members and 2866 guests.
